查看: 2852|回复: 2
AutoCAD 2012性能问题
发表于 2011-9-22 23:16:59 | 显示全部楼层 |阅读模式
  问题描述
  在AutoCAD 2012中,鼠标光标可能会在执行缩放或平移过程中,或者执行其他命令时停滞。另外也可能会觉得软件总体运行缓慢,典型的状况是在图形中附加了多个外部参照时发生。
  适用产品
  AutoCAD® 2012
  AutoCAD® Architecture 2012
  AutoCAD® Civil 3D® 2012
  AutoCAD® Electrical 2012
  AutoCAD® Map 3D 2012
  AutoCAD® Mechanical 2012
  AutoCAD® MEP 2012
  AutoCAD® Structural Detailing 2012
  解决方案
  请下载安装AutoCAD 2012 Performance Slowdown Hotfix来解决此问题: http://usa.autodesk.com/getdoc/id=DL17013122
  此hotfix适用于所有基于AutoCAD 2012的垂直产品。
  以上来自 欧特克AU技术社区http://au.autodesk.com.cn
发表于 2011-9-23 14:23:44 | 显示全部楼层
官方下载地址:
http://images.autodesk.com/adsk/ ... owdown_hf_32bit.zip
英文使用帮助:
Description of Problem
This hotfix is suitable for all AutoCAD 2012 verticals and will fix the slowdown caused by the layer control update available in the ribbon.
Installation Instructions
To Install this hotfix:
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following files:
acbol.dll
Acmgd.dll
To replace the acbol.dll and Acmgd.dll files
Close all software applications.
Navigate to your product installation folder; for example C:\Program Files\Autodesk\AutoCAD Structural Detailing 2012 - English.
Rename the affected original files:
In the product installation folder, right-click the acbol.dll file and rename it acbol.bak
In the product installation folder, right-click the Acmgd.dll file and rename it Acmgd.bak
Depending on the operating system (32 or 64-bit), double click the file:
AutoCAD2012_PerformanceSlowdown_HF_32bit.zip
OR
AutoCAD2012_PerformanceSlowdown_HF_64bit.zip
Extract acbol.dll and Acmgd.dll files to the product installation folder; for example C:\Program Files\Autodesk\AutoCAD Structural Detailing 2012 - English.
发表于 2011-9-30 10:49:06 | 显示全部楼层
没看明白!没发生这种现象!
GMT+8, 2025-5-19 05:51 , Processed in 0.161849 second(s), 28 queries , Gzip On.
