查看: 2129|回复: 3
Jig基点的问题
发表于 2011-9-13 17:01:59 | 显示全部楼层 |阅读模式
先看文字移动时的图片
 楼主| 发表于 2011-9-13 17:04:07 | 显示全部楼层
问题是为什么第一次的JIG基点不在文字角上,而第二次就真确了。
下面是JIG代码
  1. #region CAD实体移动通用函数
  2.     public class CADJig
  3.         {
  4.             /// <summary>
  5.             ///  入口函数
  6.             /// </summary>
  7.             /// <param name="ed">ed</param>
  8.             /// <param name="lstEnt">实体列表</param>
  9.             /// <param name="promp">提示</param>
  10.             /// <returns></returns>
  11.             public static bool Jig(Editor ed, List<Entity> lstEnt, Point3d pt, string promp)
  12.             {
  13.                 Jig jig = new Jig();
  14.                 jig.lstEnt = lstEnt;
  15.                 jig.ptBase = pt;
  16.                 jig.promp = promp;
  17.                 PromptResult prJig = ed.Drag(jig);
  18.                 if (prJig.Status != PromptStatus.OK)
  19.                 {
  20.                     return false;
  21.                 }
  22.                 else
  23.                 {
  24.                     return true;
  25.                 }
  26.             }
  27.         }
  28.         //本类是Jig,单独的实体或实体列表均可调用
  29.         public class Jig : DrawJig
  30.         {
  31.             private List<Entity> _lstEnt; //移动的实体
  32.             private Point3d _ptBase;   //基点
  33.             private string _promp;   //提示
  34.             /// <summary>
  35.             /// 移动的实体
  36.             /// </summary>
  37.             public List<Entity> lstEnt
  38.             {
  39.                 set { _lstEnt = value; }
  40.             }
  41.             /// <summary>
  42.             /// 基点
  43.             /// </summary>
  44.             public Point3d ptBase
  45.             {
  46.                 set { _ptBase = value; }
  47.                 get { return _ptBase; }
  48.             }
  49.             /// <summary>
  50.             /// /提示
  51.             /// </summary>
  52.             public string promp
  53.             {
  54.                 set { _promp = value; }
  55.             }
  56.             private Point3d ptTo;   //插入点
  57.             protected override SamplerStatus Sampler(JigPrompts prompts)
  58.             {
  59.                 JigPromptPointOptions optJigPoint = new JigPromptPointOptions(_promp);
  60.
  61.                 optJigPoint.UserInputControls =
  62.                        UserInputControls.Accept3dCoordinates |
  63.                        UserInputControls.NoZeroResponseAccepted |
  64.                        UserInputControls.NoNegativeResponseAccepted |
  65.                        UserInputControls.NullResponseAccepted;
  66.                 optJigPoint.Keywords.Add("Undo", "Undo", "放弃(U)");
  67.                 PromptPointResult resJigPoint = prompts.AcquirePoint(optJigPoint);
  68.                 Point3d curPt = resJigPoint.Value;
  69.                 if (ptTo != curPt)
  70.                 {
  71.                     ptTo = curPt;
  72.                     return SamplerStatus.OK;
  73.                 }
  74.                 else
  75.                 {
  76.                     ptBase = ptTo;
  77.                     return SamplerStatus.NoChange;
  78.                 }
  79.             }
  80.             protected override bool WorldDraw(WorldDraw draw)
  81.             {
  82.                 try
  83.                 {
  84.                     Matrix3d mat = Matrix3d.Displacement(ptTo - ptBase);
  85.                     foreach (Entity ent in _lstEnt)
  86.                     {
  87.                         //移动每个实体
  88.                         ent.TransformBy(mat);
  89.                         ent.RecordGraphicsModified(true);
  90.                         draw.Geometry.Draw(ent);
  91.                     }
  92.                 }
  93.                 catch (System.Exception)
  94.                 {
  95.                     return false;
  96.                 }
  97.                 return true;
  98.             }
  99.         }
  100. #endregion
发表于 2011-9-13 17:14:51 | 显示全部楼层
问下,你点击button的时候的鼠标点的左边怎么得到的?
这个是初始点,我没看到你是怎么将屏幕坐标转化为cad坐标的。
 楼主| 发表于 2011-9-13 17:43:18 | 显示全部楼层
我估计自己的问题是点击按钮关闭窗口时,基点就是设置为这个点。
JIG是网上下载的。我套用了一下。
GMT+8, 2025-5-4 06:04 , Processed in 0.160260 second(s), 24 queries , Gzip On.
