查看: 2591|回复: 1
初学vb.net,在2010里画线的例子
发表于 2011-9-10 08:30:07 | 显示全部楼层 |阅读模式
  1. Public Class Form1
  2.     Dim acadapp As Autodesk.AutoCAD.Interop.AcadApplication
  3.     Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
  4.         End
  5.     End Sub
  6.     Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
  7.         Call bj_linkautocad()
  8.         Call bj_draw()
  9.     End Sub
  10.     Sub bj_linkautocad()
  11.         On Error Resume Next
  12.         acadapp = GetObject(, "autocad.application")
  13.         If Err.Number Then
  14.             Err.Clear()
  15.             acadapp = CreateObject("autocad.application")
  16.             If Err.Number Then
  17.                 MsgBox("Can't start AutoCAD")
  18.                 Exit Sub
  19.             End If
  20.         End If
  21.         acadapp.Visible = True
  22.         AppActivate(acadapp.Caption)
  23.     End Sub
  24.     Sub bj_draw()
  25.         Dim points(3) As Double
  26.         Dim plineobj(1) As Autodesk.AutoCAD.Interop.Common.AcadLWPolyline
  27.         points(0) = 0 : points(1) = 0
  28.         points(2) = 100 : points(3) = 100
  29.         plineobj(0) = acadapp.ActiveDocument.ModelSpace.AddLightWeightPolyline(points)
  30.     End Sub
  31. End Class
用的vb.net express 2008, 在autocad 2010里从(0,0)-(100,100)画了一条线.
发表于 2011-9-12 01:16:53 | 显示全部楼层
发贴何意?
GMT+8, 2025-5-4 06:25 , Processed in 0.164602 second(s), 30 queries , Gzip On.
