查看: 3468|回复: 8
重复偏移程序原代码!
发表于 2003-7-25 21:08:00 | 显示全部楼层 |阅读模式
这个程序主要是针对在AutoCAD中做表格用的,可以根据距离重复做平行线,做表格非常方便! 原代码如下:
Sub callp()
On Error GoTo err
Dim keyWord As String
'选择偏移模式
ThisDrawing.Utility.InitializeUserInput 0, "Add Noadd"
keyWord = ThisDrawing.Utility.GetKeyword _
(vbCrLf & "输入选项[分段偏移(A)/总长偏移(N)]:<分段偏移> ")
If keyWord = "" Then keyWord = "Add" '若为空则默认分段偏移
'MsgBox keyWord
Select Case keyWord
Case "Add"
Call soffset1
Case "Noadd"
Call soffset2
End Select
err:
Exit Sub
End Sub
Sub soffset1() '分段进行偏移
'偏移命令中的偏移值是正值的情况,将在线进向的左,否在右
On Error GoTo err
Dim offdist(58) As Variant
Dim s As Integer
Dim i As Integer
Dim spnt As Variant
Dim epnt As Variant
Dim ts As String
Dim points As Variant
Dim sset As AcadSelectionSet
For i = 0 To ThisDrawing.SelectionSets.Count - 1
    ThisDrawing.SelectionSets.Item(i).Clear
    ThisDrawing.SelectionSets.Item(i).Delete
Next
Set sset = ThisDrawing.SelectionSets.Add("offsetobj")
sset.SelectOnScreen
If sset.Item(0).ObjectName = "AcDbPolyline" Then
points = sset.Item(0).Coordinates
    If points(1) > points(3) Then
            ts = "请输入偏移距离:[正值向左,负值向右]"
            ElseIf points(1) < points(3) Then
            ts = "请输入偏移距离:[正值向右,负值向左]"
            ElseIf points(1) = points(3) And points(0) < points(2) Then
             ts = "请输入偏移距离:[正值向下,负值向上]"
             ElseIf points(1) = points(3) And points(0) > points(2) Then
             ts = "请输入偏移距离:[正值向上,负值向下]"
    End If
ElseIf sset.Item(0).ObjectName = "AcDb2dPolyline" Then
    If points(1) > points(4) Then
               ElseIf points(1) < points(4) Then
               ElseIf points(1) = points(4) And points(0) < points(3) Then
                   ElseIf points(1) = points(4) And points(0) > points(3) Then
    End If
    ElseIf sset.Item(0).ObjectName = "AcDbLine" Then
    spnt = sset.Item(0).StartPoint
    epnt = sset.Item(0).EndPoint
        If spnt(1) < epnt(2) Then
            ElseIf spnt(1) > epnt(1) Then
             ElseIf spnt(1) = epnt(1) And spnt(0) < epnt(0) Then
              ElseIf spnt(1) = epnt(1) And spnt(0) > epnt(0) Then
        End If
End If
Dim offobj As Variant
offdist(0) = 0
s = 1
ss:
offdist(s) = ThisDrawing.Utility.GetReal(ts)
offdist(s) = offdist(s) + offdist(s - 1)
offobj = sset.Item(0).Offset(offdist(s))
offobj(0).Color = acGreen
s = s + 1
GoTo ss
Exit Sub
err:
Exit Sub
End Sub
Sub soffset2() '以总长进行偏移
On Error GoTo err
Dim s As Integer
Dim i As Integer
Dim ts As String
Next
sset.SelectOnScreen
    End If
    End If
            End If
End If
s = 1
ss:
s = s + 1
GoTo ss
Exit Sub
err:
Exit Sub
End Sub
发表于 2004-1-10 22:04:00 | 显示全部楼层
  1. ;fff 连续不等距offset------无痕.2000.02
  2. (defun c:mff (/ ss p1 p2 dis)
  3.   (princ "\nmff 连续不等距offset------无痕.2000.02")
  4.   (setq ss (car(entsel))
  5.         p1 (getpoint "\n <getdist> 1st pt:"))
  6.   (while (setq p2 (getpoint p1 "\n next point:")
  7.                dis (distance p1 p2)
  8.          )
  9.          (command ".offset" dis ss p2 "")
  10.          (setq ss (ssget "l")
  11.                p1 p2)
  12.   )(princ)
  13. )
发表于 2004-1-11 09:56:00 | 显示全部楼层
To 無痕:
    看來這個功能有點類似多重復制的做法, 呵呵 :D
发表于 2004-1-12 23:38:00 | 显示全部楼层
不是多重复制,你试试圆弧,或spline,就知道区别
发表于 2004-1-13 08:35:00 | 显示全部楼层
O, 我剛考慮到. 謝謝! 你說的正是.
发表于 2004-1-15 19:07:00 | 显示全部楼层
To 無痕:
你的代码少,搞个VBA的就好了!
发表于 2004-1-17 22:43:00 | 显示全部楼层
我不懂vba,不过我没太看明白你的话。:s
发表于 2004-1-21 00:16:00 | 显示全部楼层
To 無痕,BDYCAD :
呵呵!你们是牛头不对马嘴啊!
我不会,但不会乱回贴啊!
人家的VBA,到你们就是LISP了!看不懂!
发表于 2013-8-15 01:19:11 | 显示全部楼层
版主有没有办法就是
GMT+8, 2025-5-1 12:12 , Processed in 0.185315 second(s), 24 queries , Gzip On.
