查看: 2537|回复: 3
请问如何获取当前图的所有图层?
发表于 2011-8-29 11:51:51 | 显示全部楼层 |阅读模式
Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
          Transaction trans = db.TransactionManager.StartTransaction();
          try
              BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForWrite));
              BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
              //Create the block reference...use the return from CreateEmployeeDefinition directly!
              BlockReference br = new BlockReference(pStart, CreatePolePedDefinition(pCellName));
              br.LayerId = CreateLayer(pLayerName);
              ObjectId newBtrId = btr.AppendEntity(br); //Add the reference to ModelSpace
              trans.AddNewlyCreatedDBObject(br, true); //Let the transaction know about it
              DBObject obj = trans.GetObject(newBtrId, OpenMode.ForWrite);
              XDataDispose.AddRegAppTableRecord("xlentComms");
              ResultBuffer rb = new ResultBuffer(
                  new TypedValue(1001, "xlentComms"),
                  new TypedValue(1000, pMslink + "," + pEntityNo)
             obj.XData = rb;
             rb.Dispose();
             trans.Commit(); // Commit is always required to indicate success.
             Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
             //db.SaveAs(ed.Document.Name, null);
             db.SaveAs(ed.Document.Name, true, DwgVersion.Current, db.SecurityParameters);
现在要获取当前图中所有pLayerName
发表于 2011-8-29 13:48:05 | 显示全部楼层
  1. Function GetLayers() As String()
  2.
  3.         Using Trans As Transaction = DB.TransactionManager.StartTransaction
  4.             Dim LayT As LayerTable = Trans.GetObject(DB.LayerTableId, OpenMode.ForRead)
  5.             Dim ID As ObjectId, LayTR As LayerTableRecord, Lays As New List(Of String)
  6.             For Each ID In LayT
  7.                 LayTR = Trans.GetObject(ID, OpenMode.ForRead)
  8.                 Lays.Add(LayTR.Name)
  9.             Next
  10.             Trans.Commit()
  11.             GetLayers = Lays.ToArray
  12.         End Using
  13.     End Function
发表于 2011-8-29 16:38:04 | 显示全部楼层
             Database db = HostApplicationServices.WorkingDatabase;
             List<LayerTableRecord> list = new List<LayerTableRecord>();
             using (Transaction trans = db.TransactionManager.StartTransaction())
                 LayerTable layertable = (LayerTable)trans.GetObject(db.LayerTableId,
OpenMode.ForWrite);  //得到所有的层表
                 if (layertable != null)
                     foreach (ObjectId id in layertable)   //遍历层表
                          LayerTableRecord tr=trans.GetObject(id,OpenMode.ForRead)
                     as LayerTableRecord;   //获得层表记录
                          list.Add(tr);   //将所有的图层放入一个集合中
     希望能帮到你!!!
xgr
这个方法好,图层List对图层处理很方便。  发表于 2011-9-2 19:04
 楼主| 发表于 2011-8-29 16:40:42 | 显示全部楼层
谢谢!
GMT+8, 2025-5-4 05:46 , Processed in 0.169075 second(s), 25 queries , Gzip On.
