查看: 3176|回复: 6
cad块转为外部参照
发表于 2011-8-19 23:29:33 | 显示全部楼层 |阅读模式
2明经币
求助,cad 2006中将块转为外部参照,论坛中找了1个,不过加载后提示语法错误,求高手修改。
;;; BlockToXref.LSP
;;; Convert Blocks to Xrefs
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2002 JTB World, All Rights Reserved
;;; Website:www.jtbworld.com / http://jtbworld.vze.com
;;; E-mail: info@jtbworld.com / jtbworld@hotmail.com
;;; 2000-04-03 - First release
;;;   Supports nested blocks, multiple tabs
;;; Tested on AutoCAD 2000
(defun c:btx () (c:BlockToXref))
(defun c:BlockToXref (/errexitundox
olderr restoreerrexitA2k
ss ss1 e1 ix path
bsl bn bnl bl bt not_ok repl oldvport oldregenmode
typ ed layer color ltype ang ins tab oldtab
(defun errexit (s)
(princ "\nError:")
(princ s)
(restore)
(defun undox ()
(setq ss1 nil)
(setq ss2 nil)
(setvar "ctab" oldtab)
(if (> oldcvport 1) (command "._mspace") (command "._pspace"))
(setvar "cvport" oldcvport)
(setvar "regenmode" oldregenmode)
(command "._undo" "_E")
(setvar "cmdecho" oldcmdecho)
(setq *error* olderr)
(setq olderr*error*
restore undox
*error* errexit
(setq oldcmdecho (getvar "cmdecho"))
(setq oldtab (getvar "ctab"))
(setq oldcvport (getvar "cvport"))
(setq oldregenmode (getvar "regenmode"))
(setvar "cmdecho" 0)
(setvar "regenmode" 0)
(command "._UNDO" "_BE")
(setq A2k (wcmatch (getvar "ACADVER") "15*"))
(if (and A2k (/= (setq ss1 (ssget '((0 . "INSERT")))) nil))
(vl-load-com)
(setq ix 0)
(setq bsl nil) ; block selection list
(setq bnl nil) ; unique block name list
(repeat (sslength ss1)
(setq e1 (ssname ss1 ix))
(setq bn (cdr (assoc 2 (entget e1)))) ; block name
(setq bl (tblsearch "block" bn)) ; block list bn
(setq bt (cdr (assoc 70 bl))) ; block type
(if (and (/= (logand bt 4) 4) (not (member bn bnl))) ; no xrefs and no duplicates
(setq bnl (cons bn bnl))
(setq ix (1+ ix))
); end repeat
(foreach bn bnl
(setq ss1 (ssget "X" (list (cons 0 "INSERT") (cons 2 bn))))
(setq ix 0)
(setq bsl (cons (entget e1) bsl))
(setq ix (1+ ix))
); end repeat
(foreach bn bnl
(setq not_ok T)
(while not_ok
(setq path (getfiled "Match the block to a file"
(if (not path) (strcat (getvar "dwgprefix") bn) (strcat (vl-filename-directory path) "\\" bn))
"dwg" 0))
(if path
(if (= (strcase (vl-filename-basepath)) (strcase bn))
(setq not_ok nil)
(initget 0 "Yes No")
(setq repl (getkword "\nAssign a different name? [Yes/No] : "))
(if (not repl) (setq repl "Yes"))
(if (= "Yes" repl)
(setq not_ok nil)
(setq not_ok T)
(if (not not_ok)
(setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 bn))))
(setq ix 0)
(repeat (sslength ss)
(setq ed (ssname ss ix))
(setq tab (cdr (assoc 410 (entget ed))))
(setvar "ctab" tab)
(entdel ed)
(setq ix (1+ ix))
(repeat 10
(vl-cmdf "._purge" "_b" "*" "N")
(initget 0 "Overlay Attach")
(setq repl (getkword "\nEnter an option [Overlay/Attach] : "))
(if (not repl) (setq repl "Attach"))
(if (= "Attach" repl) (setq typ "_A") (setq typ "_O"))
(setq ix 0)
(repeat (length bsl)
(setq ed (nth ix bsl))
(if (= bn (cdr (assoc 2 ed)))
(setq layer (cdr (assoc 8 ed)))
(setq color (cdr (assoc 62 ed)))
(if (not color) (setq color "_ByLayer"))
(setq ltype (cdr (assoc 6 ed)))
(if (not ltype) (setq ltype "_ByLayer"))
(setq ang (/ (* 180.0 (cdr (assoc 50 ed))) pi))
(setq ins (cdr (assoc 10 ed)))
(setq tab (cdr (assoc 410 ed)))
(setvar "ctab" tab)
(if (/= tab "Model") (command "._pspace"))
(vl-cmdf "._xref" typ path "_X" (cdr (assoc 41 ed)) "_Y" (cdr (assoc 42 ed)) "_Z" (cdr (assoc 43 ed)) ins ang)
(vl-cmdf "._change" "_L" "" "_P" "_C" color "_LA" layer "_LT" ltype "")
(setq ix (1+ ix))
(if (= path nil) (setq not_ok nil))
); end progn
); end if
(restore)
最佳答案
查看完整内容
要修改一下 ;;; BlockToXref.LSP ;;; Convert Blocks to Xrefs ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2002 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com / http://jtbworld.vze.com ;;; E-mail: / ;;; 2000-04-03 - First release ;;; Supports nested blocks, multiple tabs ;;; Tested on AutoCAD 2000 (defun c:btx () (c:BlockToXref)) (defun c:BlockToXref (/ errexit ...
发表于 2011-8-19 23:29:34 | 显示全部楼层
要修改一下
;;; BlockToXref.LSP
(defun c:BlockToXref (/            errexit      undox
                      olderr       restore      errexitA2k
                      ss ss1 e1 ix path
  (defun errexit (s)
    (princ "\nError:  ")
    (princ s)
    (restore)
  (defun undox ()
    (setq ss1 nil)
    (setq ss2 nil)
  (setq olderr  *error*
        restore undox
        *error* errexit
  (setq A2k (wcmatch (getvar "ACADVER") "16*"))
      (vl-load-com)
      (setq ix 0)
        (setq ix (1+ ix))
      ); end repeat
      (foreach bn bnl
        (setq ix 0)
          (setq ix (1+ ix))
      ); end repeat
      (foreach bn bnl
        (setq not_ok T)
        (while not_ok
                               "dwg" 1))
          (if path (progn
                     (command "_.insert" bn "0,0,0" 1 1 0)
                     (command "_.wblock" path "" "0,0,0" (entlast) "")
          (if path
            (if (= (strcase (vl-filename-base  path)) (strcase bn))
              (setq not_ok nil)
                (setq repl (getkword "\nAssign a different name? [Yes/No] <No>: "))
                (if (= "Yes" repl)
                  (setq not_ok nil)
                  (setq not_ok T)
          (if (not not_ok)
              (setq ix 0)
                (setvar "ctab" tab)
                (entdel ed)
                (setq ix (1+ ix))
              (repeat 10
              (setq repl (getkword "\nEnter an option [Overlay/Attach] <Attach>: "))
              (setq ix 0)
                    (setvar "ctab" tab)
                (setq ix (1+ ix))
    ); end progn
  ); end if
  (restore)
 楼主| 发表于 2011-8-21 23:06:39 | 显示全部楼层
非常感谢,在2006里完美运行
发表于 2011-9-19 21:08:54 | 显示全部楼层
试验了一下,没有用呀程序,没有搞明白
发表于 2011-10-22 09:47:56 | 显示全部楼层
不明白楼主需要这个功能有什么好处?
发表于 2021-12-13 18:54:07 | 显示全部楼层
2楼,没有用
发表于 2022-6-22 14:52:38 | 显示全部楼层
模型里不行。
GMT+8, 2025-5-1 07:26 , Processed in 0.193309 second(s), 23 queries , Gzip On.
