查看: 3153|回复: 2
[基础] 怎么遍历DBDictionary 对象?
发表于 2011-7-28 14:59:45 | 显示全部楼层 |阅读模式
DBDictionary acDBDicNOD = acTrans.GetObject(acDatabase.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
现在相对AutoCAD中的字典数据进行遍历,但是DBDictionary 的Keys、Values为受保护对象,无法直接访问;
DbDictionaryEnumerator acDBDicEnumerator = acDBDicNOD.GetEnumerator();
当使用枚举时会抛出异常,提示无效的对象操作。
求高手字典
发表于 2011-7-28 15:29:16 | 显示全部楼层
        DBDictionary dbDictionary
        using (Transaction ctrans = smc.db.TransactionManager.StartTransaction())
          DBObject dbObj;
          foreach (System.Collections.DictionaryEntry dEntry in dbDictionary)
            dbObj = (DBObject)ctrans.GetObject((ObjectId)dEntry.Value, OpenMode.ForRead, false);
            if (dbObj is DBDictionary)
            else if (dbObj is Xrecord)
 楼主| 发表于 2011-7-28 15:52:06 | 显示全部楼层
问题解决了,感激不尽
GMT+8, 2025-5-4 05:34 , Processed in 0.244154 second(s), 24 queries , Gzip On.
