查看: 1490|回复: 1
恢复AUTOCAD MEP中的下拉菜单功能
发表于 2011-7-12 00:59:37 | 显示全部楼层 |阅读模式
我想对于其他专业版本,比如AutoCAD Architecture Structure同样适用。
我从网上搜来的,想找原链接找不到了。
软件内有英文说明(图文)
RestoringMenus and Toolbars – MEP
Manually(and where menus are on a network share)
  • Extract the files in the package        to your installed menu location.
Example(NT):C:\Documents and Settings\USER NAME\Application Data\Autodesk\MEP2010\enu\Support
Example(Vista):C:\Users\USER NAME\AppData\Roaming\Autodesk\MEP 2010\enu\Support
  • Run MEP
  • You may now load these as partial        customization files by running the “CUI” command at the command        line or selecting the Manage tab-> Customization Panel -> User        Interface button
  • In the Customize tab, open each of        the partial CUIX files you want to load. Then click OK.
  • To turn menus on, type MENUBAR and        set the value to 1. To turn them off, set the value to 0. Or you may        select the Show Menu Bar menu item from the Quick Access        Toolbar.
  • To turn all toolbars on or off,        use the –TOOLBAR command. Enter “ALL” and then enter “Show”        (or “Hide”) at the command line.
  • You may reorganize the menu bar        items using the Workspaces feature. This is where you may define the        visibility and arrangement of these elements.
  • To turn off the Ribbon, run the        RIBBONCLOSE command. The RIBBON command will restore it.
Automatically(not recommended when menu on network share)
Example(NT):C:\Documents and Settings\USER NAME\Application Data\Autodesk\MEP2010\Support
Example(Vista):C:\Users\USER NAME\AppData\Autodesk\MEP 2010\Support
  • Run MEP
  • From the command line, type        NETLOAD. Browse to the installed menu location and select        “ToolbarsMenus.dll”.
  • From the command line, type        LOADLEGACYUI.
Notes/Caveats
  • Supports the active workspace only        (WSCURRENT). Use the CUI editor to assign menus and toolbars to more        than one workspace.
  • Does not account for or support        Enterprise Menus.
  • Order of items loaded can be        edited via the CUI editor.
  • For best results load the CUIX        files in this order for MEP:
    • MEP_MAIN
    • MEP3DSOLIDS
    • MEPCADMANAGER
    • MEPDESIGN
    • MEPDOCUMENT
    • MEPELECTRICAL
    • MEPHVAC
    • MEPPIPING
    • MEPPLUMBING
    • MEPSCHEMATIC
  • You may notice duplicates of the        File, View, Edit, Insert, Format, Window pulldowns. You will need to        delete these from the MEP_MAIN partial CUIX that is loaded as the        default ACA.CUIX file has these already.
  • Use the transfer tab in the        Customize User Interface to pull over the additional menus from the        partial CUIX files to have them display on the Menu Bar.
 楼主| 发表于 2011-7-12 01:11:02 | 显示全部楼层
GMT+8, 2025-5-3 14:45 , Processed in 0.192996 second(s), 29 queries , Gzip On.
