- 积分
- 16712
- 明经币
- 个
- 注册时间
- 2011-3-22
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2011-10-14 15:44:54
显示全部楼层
;;;面积求和
;YTM,2011.2
(defun c:DE(/ OS-OLD SS1 NR1 TOT_AREA1 EN1 TXT1 SS2 NR2 TOT_AREA2 EN2 TXT2 TMP Y M D TXT012 FP MY001 MJN TXT001 KEHUHAO
SHAHAO JT ZHONGGUO EN001 P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 SPOINT MJ SS11 SS12 SS13)
(SETQ OS-OLD(GETVAR "OSMODE"))
(SETVAR "OSMODE" 0)
(command "-style" "mystyle" "Times New Roman" 5 1 0 "N" "N")
(PROMPT "\n请选择第一部分的面积")
;(if (setq ss1 (ssget '((0 . "*LINE,CIRCLE,ELLIPSE,REGION"))))
;去掉这些限定可以选择实体了,以前选择不了实体
(if (setq ss1 (ssget '()))
(setq nr1 0
tot_area1 0.0
en1 (ssname ss1 nr1)
TXT1 ""
(while en1
(command "._area" "_O" en1)
(setq tot_area1 (+ tot_area1 (ATOF(RTOS (getvar "area") 2 2)))
nr1 (1+ nr1)
TXT1 (STRCAT TXT1 "+" (RTOS (getvar "area") 2 2) )
(PROMPT "\n请选择第二部分的面积")
(if (setq ss2 (ssget '()))
(setq nr2 0
tot_area2 0.0
en2 (ssname ss2 nr2)
TXT2 ""
(while en2
(command "._area" "_O" en2)
(setq tot_area2 (+ tot_area2 (ATOF(RTOS (getvar "area") 2 2)))
nr2 (1+ nr2)
TXT2 (STRCAT TXT2 "+" (RTOS (getvar "area") 2 2) )
;itoa函数将一个【整数】转换成【字符串】,并将该字符串返回
;rtos函数将一个【实数】转换成【字符串】,并将该字符串返回
;atof将一个【字符串】转换成【实数】,并将该字符串返回
;strcat将多个字符串拼接成一个长字符串后返回
;substr将一个字符串按要求取出其中的字符
(setq tmp (rtos (getvar "cdate") 2 8) ;用于生成制图日期
y (rtos (atof (substr tmp 1 4)) 2 0)
m (rtos (atof (substr tmp 5 2)) 2 0)
d (rtos (atof (substr tmp 7 2)) 2 0)
txt012 (strcat "日期:" y "年" m "月" d "日")
(SETQ spoint (GETPOINT "\012请选择放置点:")
tp (list (car spoint) (- (cadr spoint) 8))
ddp (list (car tp) (- (cadr tp) 8))
RQP (list (car DDp) (- (cadr DDp) 8))
MYTXT001P (list (car RQP) (- (cadr RQP) 2))
CKDLP (list (car RQp) (- (cadr RQp) 8))
(SETQ MJ (RTOS(- tot_area1 tot_area2)))
(SETQ SS11 (STRCAT "S1=" (SUBSTR TXT1 2)))
(SETQ SS12 (STRCAT "S2=" (SUBSTR TXT2 2)))
(SETQ SS13 (STRCAT "S=" MJ))
;(COMMAND "_STYLE" "USER3" "TXT.SHX,GBCBIG.SHX" "5" "1" "0" "N" "N" "N" )
(if (> (cdr(assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE")))) 0)
(command "text" spoint "" SS11 "text" "" SS12
"text" "" SS13 "text" "" TXT012 "text" "" CKDL)
(command "text" spoint "5" "" SS11 "text" "" SS12
(command "text" spoint "5" "" SS11)
(command "text" tp "" "" SS12)
(command "text" ddp "" "" SS13)
(command "text" RQp "" "" TXT012)
(command "text" CKDLp "" "" CKDL)
(PRINC (- tot_area1 tot_area2))
(SETVAR "OSMODE" 16383)
(PRINC)
(GC)
);命令完成
