查看: 4064|回复: 9
[基础] 线段求和源代码(支持线段、多段线、圆、椭圆、样条曲线)
发表于 2011-6-17 13:17:11 | 显示全部楼层 |阅读模式
[CommandMethod("my")]
        public void my1()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            try
                using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    BlockTable acBlkTbl;
                    acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord acBlkTblRec;
                    acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                                    OpenMode.ForWrite) as BlockTableRecord;
                    PromptSelectionOpti** pso = new PromptSelectionOpti**();
                    PromptSelectionResult psr = ed.GetSelection(pso);
                    if (psr.Status == PromptStatus.OK)
                        Selecti**et ss = psr.Value;
                        int lcount = 0;
                        int n = ss.Count;
                        double result = 0;
                        for (int i = 0; i < n; i++)
                            Entity ent = acTrans.GetObject(ss[i].ObjectId, OpenMode.ForWrite) as Entity;
                            if (ent is Line)
                                Line l = ent as Line;
                                result += l.Length;
                                lcount++;
                                ed.WriteMessage("\n实体" + lcount + "的长度为:" + l.Length);
                            if (ent is Circle)
                                Circle c = ent as Circle;
                                result += c.Circumference;
                                lcount++;
                                ed.WriteMessage("\n实体" + lcount + "的长度为:" + c.Circumference);
                            if (ent is Ellipse)
                                Ellipse e = ent as Ellipse;
                                double zc = Math.PI * (e.MajorRadius + e.MinorRadius);
                                result += zc;
                                lcount++;
                                ed.WriteMessage("\n实体" + lcount + "的长度为:" + zc);
                            if (ent is Arc)
                                Arc arc = ent as Arc;
                                result += arc.Length;
                                lcount++;
                                ed.WriteMessage("\n实体" + lcount + "的长度为:" + arc.Length);
                            if (ent is Spline)
                                Spline s = ent as Spline;
                                Curve c = s.ToPolyline();
                                Polyline pl = c as Polyline;
                                result += pl.Length;
                                lcount++;
                                ed.WriteMessage("\n实体" + lcount + "的长度为:" + pl.Length);
                            if (ent is Polyline)
                                Polyline pl = ent as Polyline;
                                lcount++;
                            // else
                            //    lcount++;
                            //    ed.WriteMessage("\n实体" + lcount + "未计入总长!");
                        ed.WriteMessage("\n线段的总长度为:{0}", result);
                    else ed.WriteMessage("\n未选中线段!"); ;
                    acTrans.Commit();
            catch (System.Exception)
                Application.ShowAlertDialog("error");
发表于 2011-6-19 08:04:15 | 显示全部楼层
哦,不好意思!我的失误.
    if (ent is Curve)
        Curve cur = ent as Curve;
        result += cur.GetDistanceAtParameter(cur.EndParam);
       lcount++;
        ed.WriteMessage("\n实体" + lcount + "的长度为:" + cur.GetDistanceAtParameter(cur.EndParam));
发表于 2011-6-17 14:32:41 | 显示全部楼层
      if (ent is Curve)
        result += cur.Length;
        lcount++;
        ed.WriteMessage("\n实体" + lcount + "的长度为:" + cur.Length);
发表于 2011-6-18 13:31:12 | 显示全部楼层
很不错的例子...
 楼主| 发表于 2011-6-18 23:40:34 | 显示全部楼层
回复 sieben 的帖子
Curve类没有length属性啊?
发表于 2011-6-19 14:42:20 | 显示全部楼层
学习了~~~不错~~~
 楼主| 发表于 2011-6-20 13:35:19 | 显示全部楼层
回复 sieben 的帖子
嘿嘿,谢谢指点哦.......
发表于 2015-1-7 17:12:29 | 显示全部楼层
  if (ent is Ellipse)
                                result += zc;
                                lcount++;
椭圆的弧长不是这样算的吧!!!!大哥
发表于 2015-1-7 17:16:42 | 显示全部楼层
  Using AcTrans As Transaction = AcCurDb.TransactionManager.StartTransaction()
            Dim EntPro As PromptEntityOptions = New PromptEntityOptions("请选择第一条圆弧")
            Dim EntRec As PromptEntityResult = AcDocEd.GetEntity(EntPro)
            If EntRec.Status <> PromptStatus.OK Then Exit Sub
            Dim OBJ As Object = AcTrans.GetObject(EntRec.ObjectId, OpenMode.ForRead)
            Dim a As Ellipse = CType(OBJ, Ellipse)
            b = a.Spline
            MsgBox(a.GetDistAtPoint(a.EndPoint))
        End Using
这样才是对的!
发表于 2015-1-7 17:19:50 | 显示全部楼层
如果是VB的。我坚决相信把A的类型改成Object.就可以直接通用到所有的有长度的对象了!
GMT+8, 2025-5-2 00:39 , Processed in 0.204844 second(s), 25 queries , Gzip On.
