楼主: carrot1983
[求助]两线段的关系。
 楼主| 发表于 2011-6-10 08:56:24 | 显示全部楼层
;;  test for parallel   CAB 10/18/05
    (defun PARALLEL (LN1 LN2 / ANG1 ANG2 PFUZZ)
      (if (= (type LN1) 'ENAME)
        (setq LN1 (entget LN1)
              LN2 (entget LN2)
      (setq ANG1 (angle (cdr (assoc 10 LN1)) (cdr (assoc 11 LN1))))
      (setq ANG2 (angle (cdr (assoc 10 LN2)) (cdr (assoc 11 LN2))))
      (setq PFUZZ 0.001)
      (or (equal ANG1 ANG2 PFUZZ)
          ;;  Check for lines drawn in opposite directions
          (equal (min ANG1 ANG2) (- (max ANG1 ANG2) pi) PFUZZ)
发表于 2011-6-10 13:59:58 | 显示全部楼层
      (if (=  ...
假设2根直线的角度分别是359.99999999度和0.00000001度,你的程序就判断出错了,呵呵
方法1:
(inters P1 P2 P3 P4 nil)
方法2:
(setq ANG (ABS (- ANG1 ANG2)))
(or (equal ANG 0 1-E6)
      (equal ANG 0 PI 1-E6)
GMT+8, 2025-7-26 21:00 , Processed in 0.154966 second(s), 20 queries , Gzip On.
