查看: 2975|回复: 9
[函数] 求LISP下调整对象前置与后置的函数
发表于 2011-6-4 13:13:15 | 显示全部楼层 |阅读模式
求LISP下调整对象前置与后置的函数,谢谢。
发表于 2011-6-4 13:28:37 | 显示全部楼层
(defun c:ff    (/ b) (setq b(ssget))(command "draworder" b "" "f" )(prin1))
(defun c:bb    (/ b) (setq b(ssget))(command "draworder" b "" "b" )(prin1))
 楼主| 发表于 2011-6-4 14:41:36 | 显示全部楼层
回复 LLXXZZ 的帖子
谢谢,这个我知道,我不想调入命令的方式处理,速度太慢。不过还得谢谢你。
发表于 2011-6-4 14:59:07 | 显示全部楼层
vla-MoveToTop
vla-MoveToBottom
发表于 2011-6-4 16:04:30 | 显示全部楼层
回复 scry_wxj 的帖子
  1. ;;;移到最上显示 By Gu_xl  示例: (MovetoTop (ssget))
  2. (defun MovetoTop (ss / ObjLst Sortents dict i)
  3.   (cond        ((= 'pickset (type ss))
  4.          (repeat (setq i (sslength ss))
  5.            (setq ObjLst        (cons (vlax-ename->vla-object
  6.                                 (ssname ss (setq i (1- i)))
  7.                               ) ;_ vlax-ename->vla-object
  8.                               ObjLst
  9.                         ) ;_ cons
  10.            ) ;_ setq
  11.          ) ;_ repeat
  12.         )
  13.         ((= 'ename (type ss))
  14.          (setq ObjLst (list (vlax-ename->vla-object ss)))
  15.         )
  16.         ((= 'vla-object (type ss)) (setq ObjLst (list ss)))
  17.   ) ;_ cond
  18.   (if
  19.     (cond
  20.       ((not
  21.          (VL-CATCH-ALL-ERROR-P
  22.            (setq Sortents
  23.                   (VL-CATCH-ALL-APPLY
  24.                     'vla-item
  25.                     (list
  26.                       (setq dict
  27.                              (vla-GetExtensionDictionary
  28.                                (vla-ObjectIDtoObject
  29.                                  (vla-get-ActiveDocument (vlax-get-acad-object))
  30.                                  (vla-get-OwnerID (car ObjLst))
  31.                                ) ;_ vla-ObjectIDtoObject
  32.                              ) ;_ vla-GetExtensionDictionary
  33.                       ) ;_ setq
  34.                       "ACAD_SORTENTS"
  35.                     ) ;_ list
  36.                   ) ;_ GXL-CATCHAPPLY
  37.            ) ;_ setq
  38.          ) ;_ VL-CATCH-ALL-ERROR-P
  39.        ) ;_ not
  40.       )
  41.       ((not
  42.          (VL-CATCH-ALL-ERROR-P
  43.            (setq Sortents
  44.                   (VL-CATCH-ALL-APPLY
  45.                     'vla-AddObject
  46.                     (list dict "ACAD_SORTENTS" "AcDbSortentsTable")
  47.                   ) ;_ GXL-CATCHAPPLY
  48.            ) ;_ setq
  49.          ) ;_ VL-CATCH-ALL-ERROR-P
  50.        ) ;_ not
  51.       )
  52.     ) ;_ cond
  53.      (not (vla-MovetoTop
  54.             Sortents
  55.             (vlax-make-variant
  56.               (vlax-safearray-fill
  57.                 (vlax-make-safearray
  58.                   vlax-vbobject
  59.                   (cons 0 (1- (length ObjLst)))
  60.                 ) ;_ vlax-make-safearray
  61.                 ObjLst
  62.               ) ;_ vlax-safearray-fill
  63.             ) ;_ vlax-make-variant
  64.           ) ;_ vla-MovetoTop
  65.      ) ;_ not
  66.   ) ;_ if
  67. ) ;_ defun
发表于 2011-6-4 16:41:42 | 显示全部楼层
感觉调用命令的方式很简单哦!
发表于 2011-6-5 15:33:50 | 显示全部楼层
回复 LLXXZZ 的帖子
能否做到只用一个命令,在选择对象后,按一下就前置,再按一下就后置呢?这样就更完美了。
发表于 2011-6-6 14:54:23 | 显示全部楼层
    完美的要等大侠来了
发表于 2011-6-9 13:34:04 | 显示全部楼层
同求,。。。现身吧,大侠,呵呵
发表于 2011-7-24 19:06:02 | 显示全部楼层
回复 LLXXZZ 的帖子
谢谢分享,很是感激~~~~
GMT+8, 2025-7-25 10:09 , Processed in 0.174418 second(s), 26 queries , Gzip On.
