楼主: chpmould
[基础] 获取同心圆中最大圆直径
 楼主| 发表于 2011-6-9 23:50:27 | 显示全部楼层
690994 发表于 2011-6-9 15:08
象你只要求最大直径,这个比较简单,我以前要以圆之大小,线型,颜色,图层,附加数据等再判断同种孔有几 ...
你可以帮我按你所说的方式写个例子吗,示范将同心圆最大直径更改成红色即可...
发表于 2011-6-12 16:05:15 | 显示全部楼层
你试下下面这段代码,
(defun c:te( / cpt ent i itm lst r ss tem)
    (setq ss (ssget '((0 . "CIRCLE")))
          tem '()
          i 0
     (repeat (sslength ss)
            (setq ent (ssname ss i)
                  i (1+ i)
                      cpt (sam_dxf ent 10)
                      cpt(list (/ (fix(* 100000.0(car cpt)))100000.0)
                               (/ (fix(* 100000.0(cadr cpt)))100000.0)
                               (/ (fix(* 100000.0(caddr cpt)))100000.0)
                      r (sam_dxf ent 40)
                  lst (list(list r (sam_dxf ent 5)))
        (setq itm (assoc cpt tem))
            (if itm
                    (if (and (> i 1)(> r (caadr itm)))
                        (setq tem (vl-remove itm tem)
                              tem (append tem(list(append (list cpt) lst)))
                    (setq tem(append tem(list(append (list cpt) lst))))
        (setq ss (ssadd))
        (foreach x tem
           (setq ss (ssadd (handent (last(last x)))ss))
        (command "change" ss "" "p" "c" 1 "")
(defun sam_dxf (ent n)
        (if (= (type ent) 'ename)
          (cdr (assoc n (entget ent)))
有问题,不同心的圆也变色了  发表于 2018-1-6 16:41
发表于 2011-6-12 19:24:20 | 显示全部楼层
发表于 2011-6-13 08:56:43 | 显示全部楼层
要处理这么多圆?
 楼主| 发表于 2011-6-13 18:07:59 | 显示全部楼层
690994 发表于 2011-6-12 16:05
你试下下面这段代码,
    (setq ss (ssget '((0 . "C ...
谢谢你的热心帮助,现在知道你之前所说做成表的方法了...
GMT+8, 2025-7-26 16:27 , Processed in 0.218532 second(s), 21 queries , Gzip On.
