代码如下,运行的时候cad界面显示“请指定插入块角度<0>",这个0是选中状态的,如果我按回车的话,就不返回我输入的是0度,而是让我重新输入,求解。。。
 - ' 定义一个角度拖动交互类.
- Dim optJigAngle As New JigPromptAngleOptions(vbCrLf & "请指定插入块角度<0>")
- ' 设置拖拽的光标类型.
- optJigAngle.Cursor = CursorType.RubberBand
- ' 设置拖动光标基点.
- optJigAngle.BasePoint = curPt
- optJigAngle.UseBasePoint = True
- ' 用AcquireAngle函数得到用户输入的角度值.
- Dim resJigAngle As PromptDoubleResult = prompts.AcquireAngle(optJigAngle)
- temAng = resJigAngle.Value
- If Ang <> temAng Then
- ' 保存当前点角度值.
- MyBlock.Rotation = temAng
- Ang = temAng
- Return SamplerStatus.OK
- Else
- Return SamplerStatus.NoChange
- End If
