楼主: 小菜123
[资源] 小菜版选择易,欢迎使用并提出完善建议
发表于 2011-10-11 17:00:49 | 显示全部楼层
强烈支持楼主,可惜我没有币了,很期待看到源码
发表于 2011-10-11 17:32:36 | 显示全部楼层
能否增加按照扩展数据来进行过滤选择呢?
 楼主| 发表于 2011-10-11 17:49:20 | 显示全部楼层
扩展数据,从未涉猎,请传图说明什么要求
发表于 2011-10-12 15:50:55 | 显示全部楼层
非常好用的程序,谢谢了
发表于 2011-10-13 18:39:12 | 显示全部楼层
你好呀,我下载了,怎么全是些不相关的内容呀,我是菜鸟,能不能帮我解释下不?花了一个币, ss_v1.21.LSP (72.19 KB, 下载次数: 163, 售价: 1 个明经币)
大家帮忙看下,这个里面是否有程序,我怎么下载下来,没有看到程序呀
(我是直接把后缀php删了,不知道是不是这个原因造成错误的)
copy的内容如下:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gbk" />
<title>提示信息 -  明经通道 -  Powered by Discuz!</title>
<meta name="keywords" content="" />
<meta name="description" content=",明经通道" />
<meta name="generator" content="Discuz! X2" />
<meta name="author" content="Discuz! Team and Comsenz UI Team" />
<meta name="copyright" content="2001-2011 Comsenz Inc." />
<meta name="MSSmartTagsPreventParsing" content="True" />
<meta http-equiv="MSThemeCompatible" content="Yes" />
<base href="http://bbs.mjtd.com/" /><link rel="stylesheet" type="text/css" href="data/cache/style_1_common.css?B0m" /><link rel="stylesheet" type="text/css" href="data/cache/style_1_forum_attachment.css?B0m" /><script type="text/javascript">var STYLEID = '1', STATICURL = 'static/', IMGDIR = 'static/image/common', VERHASH = 'B0m', charset = 'gbk', discuz_uid = '0', cookiepre = 'ncjy_08db_', cookiedomain = '.mjtd.com', cookiepath = '/', showusercard = '1', attackevasive = '0', disallowfloat = 'newthread', creditnotice = '1|通道币|个,2|威望|,3|明经币|个,4|金钱|,5|贡献|,6|激情|', defaultstyle = '', REPORTURL = 'aHR0cDovL2Jicy5tanRkLmNvbS9mb3J1bS5waHA/bW9kPWF0dGFjaG1lbnQmYWlkPU5UZzFNeko4T1daallXSXlZbUY4TVRNeE9EVXdNakF5Tm53ek9UVTRNRGg4T0RZMk1UQT0=', SITEURL = 'http://bbs.mjtd.com/', JSPATH = 'static/js/';</script>
<script src="static/js/common.js?B0m" type="text/javascript"></script><meta name="application-name" content="明经通道" />
<meta name="msapplication-tooltip" content="明经通道" />
<meta name="msapplication-task" content="name=首页;action-
 楼主| 发表于 2011-10-13 21:46:36 | 显示全部楼层
不要用迅雷等下载工具,直接通过浏览器下载试试
发表于 2011-10-14 13:24:49 | 显示全部楼层
例如:带公差尺寸
((-1 . <图元名: 7e211d78>) (0 . "DIMENSION") (330 . <图元名:
7e211d18>) (5 . "2F") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0")
(100 . "AcDbDimension") (2 . "*D1") (10 367.325 143.485 0.0) (11 296.761
147.027 0.0) (12 0.0 0.0 0.0) (70 . 32) (1 . "") (71 . 5) (72 . 1) (41 . 1.0)
(42 . 141.129) (52 . 0.0) (53 . 0.0) (54 . 0.0) (51 . 0.0) (210 0.0 0.0 1.0) (3
. "ISO-25") (100 . "AcDbAlignedDimension") (13 226.196 127.883 0.0) (14 367.325
127.883 0.0) (15 0.0 0.0 0.0) (16 0.0 0.0 0.0) (40 . 0.0) (50 . 0.0) (100 .
"AcDbRotatedDimension") (-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 47)
(1040 . 0.36) (1070 . 48) (1040 . 0.15) (1070 . 147) (1040 . 0.625) (1070 . 72)
(1070 . 0) (1070 . 71) (1070 . 1) (1002 . "}"))))
选取上公差为+0.36,下公差为-0.15的所有尺寸。
对小菜来说,小菜一碟:)  发表于 2011-10-14 14:27
发表于 2011-10-14 22:34:30 | 显示全部楼层
使用发现对天正自定义的支持有写问题 比如 索引符号 TCH_INDEXPOINTER 的上下说明文字,对不是全数字的内容不能正确显示,其他自定义对象不知道是否有这个问题;索引图名TCH_DRAWINGINDEX,索引的页码没有显示。另外,是否有办法显示天正的尺寸数字,我一直找不到办法。
 楼主| 发表于 2011-10-14 22:47:57 | 显示全部楼层
尺寸的公差是容易加上的,但还有其它扩展数据么?
因为我不会用天正,也没有天正软件,所有天正的问题,都请传样图
发表于 2011-10-15 23:55:06 | 显示全部楼层
没有天正软件,如何看的到天正定义对象呢,文件已经上传,天正8.0的文件
GMT+8, 2025-12-12 08:33 , Processed in 0.193644 second(s), 21 queries , Gzip On.
