查看: 5149|回复: 26
将此种格式读入CAD里? 见内容
发表于 2011-4-7 17:16:07 | 显示全部楼层 |阅读模式
1明经币
C    =  92.69420 , -9.59426 , 2.00000
C    =  92.69420 , 4.12522 , 2.00000
C    =  92.69420 , 17.84470 , 2.00000
C    =  92.69420 , 31.56418 , 2.00000
C    =  115.41973 , -9.59426 , 2.00000
C    =  115.41973 , 4.12522 , 2.00000
C    =  115.41973 , 17.84470 , 2.00000
C    =  115.41973 , 31.56418 , 2.00000
C    =  138.14525 , -9.59426 , 2.00000
C    =  138.14525 , 4.12522 , 2.00000
C    =  138.14525 , 17.84470 , 2.00000
C    =  138.14525 , 31.56418 , 2.00000
C    =  160.87078 , -9.59426 , 2.00000
C    =  160.87078 , 4.12522 , 2.00000
C    =  160.87078 , 17.84470 , 2.00000
C    =  160.87078 , 31.56418 , 2.00000
C    =  183.59630 , -9.59426 , 2.00000
C    =  183.59630 , 4.12522 , 2.00000
C    =  183.59630 , 17.84470 , 2.00000
C    =  183.59630 , 31.56418 , 2.00000
L    =  41.56177 , -55.42973 , 41.56177 , 77.39965
A    =  42.56177 , 77.39965 , 41.56177 , 77.39965 , 42.56177 , 78.39965, S
L    =  42.56177 , 78.39965 , 233.72873 , 78.39965
A    =  233.72873 , 77.39965 , 233.72873 , 78.39965 , 234.72873 , 77.39965, S
L    =  234.72873 , 77.39965 , 234.72873 , -55.42973
A    =  233.72873 , -55.42973 , 234.72873 , -55.42973 , 233.72873 , -56.42973, S
L    =  233.72873 , -56.42973 , 42.56177 , -56.42973
A    =  42.56177 , -55.42973 , 42.56177 , -56.42973 , 41.56177 , -55.42973, S
L代表线条
A代表圆弧
C代表圆形
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
;;; 只通过您所附文件的调试
发表于 2011-4-7 17:16:08 | 显示全部楼层
  1.     (defun parse (str delim / lst pos)
  2.        (setq pos (vl-string-search delim str))
  3.        (while pos
  4.          (setq lst (cons (substr str 1 pos) lst)
  5.                str (substr str (+ pos 2))
  6.                pos (vl-string-search delim str)
  7.          )
  8.        )
  9.        (if (> (strlen str) 0)
  10.          (setq lst (cons str lst))
  11.        )
  12.        (reverse lst)
  13.     )
  14. ;;===================================================
  15. ;; ("A" "233.72873" "77.39965" "233.72873" "78.39965" "234.72873" "77.39965" "S")
  16. (defun DA ()
  17.   ;; (setq strLst (reverse (cdr (reverse StrLst)))
  18.    (command "Arc"
  19.      (list (read (nth 5 StrLst)) (atof (nth 6 StrLst)))
  20.      "C"
  21.      (strcat (cadr strlst) "," (caddr StrLst))
  22.      (strcat (cadddr strlst) "," (nth 4 StrLst))
  23.    )
  24. )
  25. (defun DL ()
  26.    (command "Line"
  27.      (strcat (cadr strlst) "," (caddr StrLst))
  28.      (strcat (cadddr strlst) "," (last StrLst))
  29.      ""
  30.    )
  31. )
  32. (defun Dc ()
  33.    (command "Circle"
  34.      (strcat (cadr strlst) "," (caddr StrLst))
  35.      (read (last StrLst))
  36.    )
  37. )
  38. ;;; No error trap
  39. ;;; for test only
  40. (defun C:Test ()
  41.    ;; (setq Df (getfiled "Select a Dat File" (getvar"DwgPrefix") "Dat" 8)
  42.    (setq Df (getfiled "Select a Dat File" "" "Dat" 8)
  43.          fp (open Df "r")
  44.    )
  45.    (setvar "OsMode" 0)
  46.    ;; (setq str "A    =  233.72873 , 77.39965 , 233.72873 , 78.39965 , 234.72873 , 77.39965, S")
  47.    (while (setq str (read-line fp))
  48.      (setq strLst (vl-remove "," (vl-remove "=" (vl-remove "" (parse str " "))))
  49.              str0 (car strLst)
  50.      )
  51.      (cond
  52.       ((= str0 "C") (Dc))
  53.       ((= str0 "L") (DL))
  54.       ((= str0 "A") (DA))
  55.       (T (alert "*** Do Nothing ...."))
  56.      )
  57.    )
  58.    (close fp)
  59. )
;;; 只通过您所附文件的调试
发表于 2011-4-7 19:27:11 | 显示全部楼层
 楼主| 发表于 2011-4-8 09:18:31 | 显示全部楼层
xyp1964版主,
很感谢你的程序啊,并不是本人不支持你的工具,只是不适用很多的功能,
有没单一的支持程序,谢谢
发表于 2011-4-8 09:49:34 | 显示全部楼层
...A代表圆弧...
能对 A = ..... 的数据加以解说吗?
 楼主| 发表于 2011-4-8 10:05:45 | 显示全部楼层
a           圆心,                                          起点                         终点     s
以上是数据
发表于 2011-4-8 10:50:01 | 显示全部楼层
为何有相同的数据,重复作何解
 楼主| 发表于 2011-4-8 11:41:27 | 显示全部楼层
代表着起点或终点和圆心在同一直线上,你看我附上的图档,查相对坐标就明白了,谢谢
发表于 2011-4-8 13:22:09 | 显示全部楼层
linheyuanpcb 发表于 2011-4-8 09:18
xyp1964版主,
有没单一的支持程序 ...
就是单一的……
发表于 2011-4-8 13:26:14 | 显示全部楼层
学习学习.....
GMT+8, 2025-5-25 19:34 , Processed in 0.155443 second(s), 22 queries , Gzip On.
