查看: 5767|回复: 19
[JIG] DrawJig闪烁
发表于 2011-3-28 09:30:45 | 显示全部楼层 |阅读模式
重写DrawJig的方法时,
绘制出来的实体一直在闪烁。
应该是WorldDraw一直在捕获光标位置重绘的问题。
但是除了计算光标上一次到本次距离,来减少重绘的次数,
让闪烁不是那么明显,是否还有别的科学的方法呢。
对重绘的内部机制了解的不是特别清楚,
求高手解答。
多谢!
发表于 2020-9-29 15:53:10 | 显示全部楼层
应该不是代码的问题。以下这段代码是gile 大神写的。
  public class MoveJig : DrawJig
        protected Point3d basePt;
        protected Entity[] entities;
        public MoveJig(Entity[] entities, Point3d basePt)
            this.entities = entities;
            this.basePt = basePt;
        public Matrix3d Displacement { get; private set; }
        protected override SamplerStatus Sampler(JigPrompts prompts)
            var options = new JigPromptPointOptions("\nSecond point: ");
            options.UserInputControls = UserInputControls.Accept3dCoordinates;
            options.BasePoint = basePt;
            options.UseBasePoint = true;
            options.Cursor = CursorType.RubberBand;
            var result = prompts.AcquirePoint(options);
            if (basePt.DistanceTo(result.Value) < Tolerance.Global.EqualPoint)
                return SamplerStatus.NoChange;
            Displacement = Matrix3d.Displacement(result.Value - basePt);
            return SamplerStatus.OK;
        protected override bool WorldDraw(WorldDraw draw)
            var geo = draw.Geometry;
            if (geo != null)
                geo.PushModelTransform(Displacement);
                foreach (var ent in entities) geo.Draw(ent);
                geo.PopModelTransform();
            return true;
        [CommandMethod("TEST", CommandFlags.UsePickSet)]
        public void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var selection = ed.GetSelection();
            if (selection.Status != PromptStatus.OK) return;
            var ptResult = ed.GetPoint("\nBase point: ");
            if (ptResult.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Entity[] entities = new Entity[selection.Value.Count];
                for (int i = 0; i < selection.Value.Count; i++)
                    entities[i] = (Entity)tr.GetObject(selection.Value[i].ObjectId, OpenMode.ForRead);
                var jig = new MoveJig(entities, ptResult.Value.TransformBy(ed.CurrentUserCoordinateSystem));
                var result = ed.Drag(jig);
                if (result.Status == PromptStatus.OK)
                        ent.UpgradeOpen();
                        ent.TransformBy(jig.Displacement);
                tr.Commit();
发表于 2020-9-30 08:51:13 | 显示全部楼层
    /// <summary>
    /// 模拟AutoCAD移动命令Move
    /// </summary>
    public void sMoveJig()
      try
        PromptSelectionResult psres = ac.ed.GetSelection();
        if (psres.Status != PromptStatus.OK)
          return;
        ents = new Entity[psres.Value.Count];
        using (Transaction ctrans = ac.db.TransactionManager.StartTransaction())
          for (int i = 0; i < psres.Value.Count; i++)
            Entity ent = (Entity)ctrans.GetObject(psres.Value[i].ObjectId, OpenMode.ForRead);
            ents[i] = (Entity)ent.Clone();
          ctrans.Commit();
        PromptPointResult ppRes = ac.ed.GetPoint("\n基准点");
        if (ppRes.Status != PromptStatus.OK)
          return;
        Point3d startPoint = ppRes.Value;
        _PrePosition = startPoint;
        PromptResult pres = ac.ed.Drag(this);
        if (pres.Status == PromptStatus.OK)
          Vector3d displacementVector = _CurPosition - startPoint;
              Entity ent = (Entity)ctrans.GetObject(psres.Value[i].ObjectId, OpenMode.ForWrite);
              ent.TransformBy(Matrix3d.Displacement(displacementVector));
            ctrans.Commit();
      catch (System.Exception ex)
        ae.WriteMessage(ex);
      finally
        for (int i = 0; i < ents.Length; i++)
          ents[i].Dispose();
发表于 2020-9-30 08:58:06 | 显示全部楼层
    /// <summary>
    /// 模拟AutoCAD复制命令Copy
    /// </summary>
    [CommandMethod("sCOPY")]
    static public void sCmd_Copy()
      aModifyJig tJig = new aModifyJig();
      tJig.sCopyJig();
    /// <summary>
    /// </summary>
    public void sCopyJig()
      try
        PromptSelectionResult psRes = ac.ed.GetSelection();
        if (psRes.Status != PromptStatus.OK) return;
        ents = new Entity[psRes.Value.Count];
          for (int i = 0; i < psRes.Value.Count; i++)
            Entity ent = (Entity)ctrans.GetObject(psRes.Value[i].ObjectId, OpenMode.ForRead);
          ctrans.Commit();
        aApp.SetSystemVariable("OSMODE", 16383);
        _PrePosition = ac.ed.GetPoint("\nBase Point").Value;
          DBObjectCollection dbClt = new DBObjectCollection();
            dbClt.Add(ents[i]);
          an.DrawEntity(dbClt, aEntclls.Null, false);
        else
            ents[i].Dispose();
          ents[i].Dispose();
发表于 2011-3-28 14:41:33 | 显示全部楼层
这个MS不好解决,你看CAD中,插入块的操作,就可以看出来,也是一直闪烁的
 楼主| 发表于 2011-3-28 18:22:29 | 显示全部楼层
恩,多谢!
现在用了一个比较笨的方法解决。
就是先把实体加入到块表中,
然后再WorldDraw的时候改实体的某些属性,
这样就不会闪了。
但是具体原理我还不是很清楚。
希望高手能解答。
多谢。
发表于 2011-5-26 20:57:22 | 显示全部楼层
一直都应该是你这种做法啊,先创建Block定义,然后创建Reference去Jig。
发表于 2011-9-17 09:40:19 | 显示全部楼层
请问您改了实体的哪些属性,就不闪烁了,等待回复中.....
发表于 2020-9-28 23:09:04 | 显示全部楼层
最近在折腾,确实没法解决闪烁的问题 。用lisp的grread函数,都不会这么闪。其它人有没有解决办法?
发表于 2020-9-29 09:21:39 | 显示全部楼层
Jig闪烁是自己的问题,请检查自己代码,检查是否使用正确的jig
发表于 2020-9-29 15:54:02 | 显示全部楼层
Jig闪烁,出来的效果就像是cad的move命令一样。但是,如果我用lisp的grread函数就不会。
发表于 2020-9-29 16:05:45 | 显示全部楼层
以下是用lisp 写的。效果很稳,不会像CAD自带move命令和8楼的movejig。不会闪烁。
(defun C:TEST (/ DATA GRR GRRPT KEY LOOP OBJECTS PT SS)
  ;; by carrot1983 2020.09.29
  (setq SS (ssget))
  (setq PT (getpoint "\n指定点:"))
  (setq OBJECTS (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))))
  (setq LOOP t)
  (while LOOP
    (setq GRR (grread t 15 2))
    (setq KEY (car GRR))
    (setq DATA (cadr GRR))
    (cond ((= KEY 5)
           (setq GRRPT DATA)
           (foreach O OBJECTS
             (vla-move O (vlax-3d-point PT) (vlax-3d-point GRRPT))
          ) ;_移动
          ((or (= KEY 3) (= DATA 13))
           (setq LOOP NIL)
          ) ;_3左击 13回车 表示确认
          ((member KEY '(12 25))
           (redraw)
           (setq LOOP NIL)
          ) ;_右键退出
    (setq PT GRRPT) ;_新基点
  (redraw)
GMT+8, 2025-5-1 13:02 , Processed in 0.177442 second(s), 27 queries , Gzip On.
