楼主: xiaxiang
用lisp操作文本文件
 楼主| 发表于 2011-2-24 09:13:28 | 显示全部楼层
回复 Andyhon 的帖子
第一个比较简单,可用方式为:
1.Doslib 中的
  1. (dos_delete "C:\\WINDOWS\\d.ini")
复制代码
2.vlisp
  1. (vl-file-delete "C:\\Windows\\d.ini").
复制代码
3.命令行方式
  1. (command "del" "C:\\WINDOWS\\d.ini" "delay" "500")
但是会出现DOS提示框,比较讨厌。
第二个麻烦一些。
1.用您给的代码再加上自己的笨办法做了一个。
  1. (defun c:cs(/ X  YH_FILE )
  2.   (vl-load-com)
  3.   (command)
  4.   (setq x (mapcar '1+
  5.   (vl-string->list (menucmd "m=$(edtime,$(getvar,date),YYYYMODD)"))
  6. )
  7. )
  8. (progn
  9.    (setq YH_file (open "C:\\1.txt" "W"))
  10.   (write-line  (rtos (car x)) YH_file)
  11.   ;(write-line   (rtos (car(cdr x))) YH_file)
  12.     (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  13.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  14.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  15.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  16.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  17.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  18.   (write-line   (rtos  (car(setq x (cdr x)))) YH_file)
  19.    (close YH_file)
  20.    )
  21. )
2.这个比较好一些
  1. (defun c:cs(/ X n open_file )
  2. (setq open_file (open "C:\\Windows\\d.ini" "w") )
  3. (setq a (substr (rtos (getvar "CDATE") 2 0) 1 8 ) )
  4. ;(foreach n (mapcar '(lambda (x) (+ x 1)) (vl-string->list a))
  5. (foreach n (mapcar '1+ (vl-string->list a))
  6.   (princ n open_file)
  7.   (princ "\n" open_file)
  8.   )
  9. (close open_file)
  10. )
 楼主| 发表于 2011-2-24 09:25:34 | 显示全部楼层
LONGXIN 发表于 2011-2-24 00:32
回复 xiaxiang 的帖子
使用位移加密太弱了吧,可以考虑使用ascii加BOOLE
可否详细说说。。。
GMT+8, 2025-5-26 03:45 , Processed in 0.159060 second(s), 22 queries , Gzip On.
