查看: 1799|回复: 2
VB读取DXF文件之一
发表于 2011-1-30 15:37:16 | 显示全部楼层 |阅读模式
Option Explicit
Private Const RADIN = 3.1415926 / 180
Type ENTITY
    lEntityId As Long
    sEntityName As String
    fEntityLength As Double
    lEntityColor As Long
    fStartX As Double
    fStartY As Double
    fEndX As Double
    fEndY As Double
    fBoundingBoxLeft As Double
    fBoundingBoxBottom As Double
    fBoundingBoxRight As Double
    fBoundingBoxTop As Double
    sLayer As String
End Type
Type LAYER
    lIndex As Long
    sName As String
    lNum As Long
End Type
Type PTLWPL
    x As Double
    y As Double
    fBulbe As Double
End Type
Private Sub ReadDXF(ByVal dxfFile As String)
    Dim colors As Variant
    colors = Array( _
                    RGB(255, 255, 255), RGB(255, 0, 0), RGB(255, 255, 0), RGB(0, 255, 0), RGB(0, 255, 255), RGB(0, 0, 255), RGB(255, 0, 255), RGB(255, 255, 255), RGB(128, 128, 128), RGB(192, 192, 192), RGB(255, 0, 0), RGB(255, 127, 127), RGB(204, 0, 0), RGB(204, 102, 102), RGB(153, 0, 0), RGB(153, 76, 76), RGB(127, 0, 0), RGB(127, 63, 63), RGB(76, 0, 0), RGB(76, 38, 38), RGB(255, 63, 0), _
                    RGB(255, 159, 127), RGB(204, 51, 0), RGB(204, 127, 102), RGB(153, 38, 0), RGB(153, 95, 76), RGB(127, 31, 0), RGB(127, 79, 63), RGB(76, 19, 0), RGB(76, 47, 38), RGB(255, 127, 0), RGB(255, 191, 127), RGB(204, 102, 0), RGB(204, 153, 102), RGB(153, 76, 0), RGB(153, 114, 76), RGB(127, 63, 0), RGB(127, 95, 63), RGB(76, 38, 0), RGB(76, 57, 38), RGB(255, 191, 0), RGB(255, 223, 127), RGB(204, 153, 0), _
                    RGB(204, 178, 102), RGB(153, 114, 0), RGB(153, 133, 76), RGB(127, 95, 0), RGB(127, 111, 63), RGB(76, 57, 0), RGB(76, 66, 38), RGB(255, 255, 0), RGB(255, 255, 127), RGB(204, 204, 0), RGB(204, 204, 102), RGB(153, 153, 0), RGB(153, 153, 76), RGB(127, 127, 0), RGB(127, 127, 63), RGB(76, 76, 0), RGB(76, 76, 38), RGB(191, 255, 0), RGB(223, 255, 127), RGB(153, 204, 0), RGB(178, 204, 102), RGB(114, 153, 0), _
                    RGB(133, 153, 76), RGB(95, 127, 0), RGB(111, 127, 63), RGB(57, 76, 0), RGB(66, 76, 38), RGB(127, 255, 0), RGB(191, 255, 127), RGB(102, 204, 0), RGB(153, 204, 102), RGB(76, 153, 0), RGB(114, 153, 76), RGB(63, 127, 0), RGB(95, 127, 63), RGB(38, 76, 0), RGB(57, 76, 38), RGB(63, 255, 0), RGB(159, 255, 127), RGB(51, 204, 0), RGB(127, 204, 102), RGB(38, 153, 0), RGB(95, 153, 76), _
                    RGB(31, 127, 0), RGB(79, 127, 63), RGB(19, 76, 0), RGB(47, 76, 38), RGB(0, 255, 0), RGB(127, 255, 127), RGB(0, 204, 0), RGB(102, 204, 102), RGB(0, 153, 0), RGB(76, 153, 76), RGB(0, 127, 0), RGB(63, 127, 63), RGB(0, 76, 0), RGB(38, 76, 38), RGB(0, 255, 63), RGB(127, 255, 129), RGB(0, 204, 51), RGB(102, 204, 127), RGB(0, 153, 38), RGB(76, 153, 95), RGB(0, 127, 31), RGB(63, 127, 79), _
                    RGB(0, 76, 19), RGB(38, 76, 47), RGB(0, 255, 127), RGB(127, 255, 191), RGB(0, 204, 102), RGB(102, 204, 153), RGB(0, 153, 76), RGB(76, 153, 114), RGB(0, 127, 63), RGB(63, 127, 95), RGB(0, 76, 38), RGB(38, 76, 57), RGB(0, 255, 191), RGB(127, 255, 223), RGB(0, 204, 153), RGB(102, 204, 178), RGB(0, 153, 114), RGB(76, 153, 133), RGB(0, 127, 95), RGB(63, 127, 111), RGB(0, 76, 57), RGB(38, 76, 66), RGB(0, 255, 255), _
                    RGB(127, 255, 255), RGB(0, 204, 204), RGB(102, 204, 204), RGB(0, 153, 153), RGB(76, 153, 153), RGB(0, 127, 127), RGB(63, 127, 127), RGB(0, 76, 76), RGB(38, 76, 76), RGB(0, 191, 255), RGB(127, 223, 255), RGB(0, 153, 204), RGB(102, 178, 204), RGB(0, 114, 153), RGB(76, 133, 153), RGB(0, 95, 127), RGB(63, 111, 127), RGB(0, 57, 76), RGB(38, 66, 76), RGB(0, 127, 255), RGB(127, 191, 255), RGB(0, 102, 204), _
                    RGB(102, 153, 204), RGB(0, 76, 153), RGB(76, 114, 153), RGB(0, 63, 127), RGB(63, 95, 127), RGB(0, 38, 76), RGB(38, 57, 76), RGB(0, 63, 255), RGB(127, 159, 255), RGB(0, 51, 204), RGB(102, 127, 204), RGB(0, 38, 153), RGB(76, 95, 153), RGB(0, 31, 127), RGB(63, 79, 127), RGB(0, 19, 76), RGB(38, 47, 76), RGB(0, 0, 255), RGB(127, 127, 255), RGB(0, 0, 204), RGB(102, 102, 204), RGB(0, 0, 153), RGB(76, 76, 153), _
                    RGB(0, 0, 127), RGB(63, 63, 127), RGB(0, 0, 76), RGB(38, 38, 76), RGB(63, 0, 255), RGB(159, 127, 255), RGB(51, 0, 204), RGB(127, 102, 204), RGB(38, 0, 153), RGB(95, 76, 153), RGB(31, 0, 127), RGB(79, 63, 127), RGB(19, 0, 76), RGB(47, 38, 76), RGB(127, 0, 255), RGB(191, 127, 255), RGB(102, 0, 204), RGB(153, 102, 204), RGB(76, 0, 153), RGB(114, 76, 153), _
                    RGB(63, 0, 127), RGB(95, 63, 127), RGB(38, 0, 76), RGB(57, 38, 76), RGB(191, 0, 255), RGB(223, 127, 255), RGB(153, 0, 204), RGB(178, 102, 204), RGB(114, 0, 153), RGB(133, 76, 153), RGB(95, 0, 127), RGB(111, 63, 127), RGB(57, 0, 76), RGB(66, 38, 76), RGB(255, 0, 255), RGB(255, 127, 255), RGB(204, 0, 204), RGB(204, 102, 204), RGB(153, 0, 153), RGB(153, 76, 153), _
                    RGB(127, 0, 127), RGB(127, 63, 127), RGB(76, 0, 76), RGB(76, 38, 76), RGB(255, 0, 191), RGB(255, 127, 223), RGB(204, 0, 153), RGB(204, 102, 178), RGB(153, 0, 114), RGB(153, 76, 133), RGB(127, 0, 95), RGB(127, 63, 111), RGB(76, 0, 57), RGB(76, 38, 66), RGB(255, 0, 127), RGB(255, 127, 191), RGB(204, 0, 102), RGB(204, 102, 153), RGB(153, 0, 76), RGB(153, 76, 114), _
                    RGB(127, 0, 63), RGB(127, 63, 95), RGB(76, 0, 38), RGB(76, 38, 57), RGB(255, 0, 63), RGB(255, 127, 159), RGB(204, 0, 51), RGB(204, 102, 127), RGB(153, 0, 38), RGB(153, 76, 95), RGB(127, 0, 31), RGB(127, 63, 79), RGB(76, 0, 19), RGB(76, 38, 47), RGB(51, 51, 51), RGB(91, 91, 91), RGB(132, 132, 132), RGB(173, 173, 173), RGB(214, 214, 214), RGB(255, 255, 255) _
    Dim codes As Variant
    Dim lastObj As String
    Dim xs, ys, xe, ye, t
    Dim ent As ENTITY
    Dim u As Long
    Dim pts() As PTLWPL
    Dim arrLayer() As LAYER
    Dim lIndex As Long
    Dim lItem As Long
    Dim coordinates(0 To 3) As Double
    Dim lw As AcadLWPolyline
    Dim fLen As Double
    Dim fBulbe As Double
    Dim xm As Double, ym As Double, xc As Double, yc As Double
    Dim fChord As Double, fInclAng As Double, fAng As Double, fRad As Double, fFlag As Double, c As Double, d As Double, h As Double
发表于 2011-3-10 19:53:25 | 显示全部楼层
顶!!!!!!!!!!!!!!!!!!!!
发表于 2012-2-6 03:49:34 | 显示全部楼层
GMT+8, 2025-5-25 05:40 , Processed in 0.142228 second(s), 24 queries , Gzip On.
