楼主: yjpzc
取cass断面数据
发表于 2012-2-8 22:02:10 | 显示全部楼层
取横断面、纵断面数据?
发表于 2012-2-24 21:52:23 | 显示全部楼层
提取断面数据 我发一个,源码如下:
(defun c:tqdmsj()
(srcs_data)
(sjdc_data)
(princ (strcat "\n文件写至" ffn))
(prin1)
(defun srcs_data()
  (setq ffn (getfiled "选取/建立数据导出文件" "" "hdm" 1))
  (setq ff (open ffn "w"))
  (close ff)
  (setq hxbl (getint "\n请输入断面横向比例 1 :"))
  (setq zxbl (getint "\n请输入断面纵向比例 1 :"))
(defun sjdc_data()
(alert "请选择需要导出数据的断面线")
(setq ss (ssget))
(setq i 0)
(setq gcz 0.00)
(repeat (sslength ss)
    (setq ssn (ssname ss i))
    (setq endata (entget ssn))
    (setq zh (getstring (strcat "\n请输入第" (rtos (1+ i) 2 3) "个断面的桩号:")))
    (if (= zh "") (setq zh (1+ i)))
    (setq qd (getpoint "\n请输入该断面中桩点的位置:"))
    (setq qdx (car qd)) (setq qdy (cadr qd))
    (setq bak gcz)
    (setq gcz (getreal (strcat "\n请输入中桩点的高程:<" (rtos bak 2 3) ">")))
    (if (= gcz nil) (setq gcz bak))
    (setq ff (open ffn "a"))
    (princ "begin," ff) (princ zh ff) (princ "," ff) (princ (rtos (1+ i) 2 3) ff) (princ "\n" ff) (close ff)
    (tqzb_data)
    (setq i (1+ i))
(prin1)
(defun tqzb_data()
(setq n 0)
(repeat (length endata)
   (setq pp (nth n endata))
   (setq key (car pp))
   (if (= key 10)
          (setq x (cadr pp)) (setq y (caddr pp))
          (setq dx (/ (- x qdx) (/ 1000 hxbl)))
          (setq dy (+ (/ (- y qdy) (/ 1000 zxbl)) gcz) )
          (princ (rtos dx 2 3) ff) (princ "," ff) (princ (rtos dy 2 3) ff) (princ "\n" ff)
          (close ff)
   (setq n (1+ n))
(prin1)
(prompt "提示:用<tqdmsj>命令来运行本程序")
发表于 2012-6-6 20:23:36 | 显示全部楼层
c#怎么用啊
发表于 2012-6-12 00:25:25 | 显示全部楼层
下载试试,看下能不能用!!!
发表于 2012-6-20 19:50:37 | 显示全部楼层
看不懂。。。
发表于 2012-12-22 10:59:31 | 显示全部楼层
纵断面中含有曲线段时,不知怎么样
发表于 2012-12-26 21:33:33 | 显示全部楼层
顶一个,,,都现源码了,,,,
发表于 2013-12-2 15:52:54 | 显示全部楼层
学习,,学习!!!
发表于 2013-12-12 15:12:39 | 显示全部楼层
还要买啊?都看不明白
发表于 2017-9-10 18:23:06 | 显示全部楼层
怎么挣币呢???
GMT+8, 2025-5-1 08:57 , Processed in 0.168707 second(s), 21 queries , Gzip On.
