查看: 3397|回复: 2
[资源] AutoCAD 2012(Ironman) 将增强的 .NET API
发表于 2010-11-29 00:00:26 | 显示全部楼层 |阅读模式
AutoCAD 2012(Ironman) 将增强的 .NET API,开发平台VS2010+.NET 4.0
  1. Associative Array API
  2. Comprehensive API for new associative array feature
  3. Grip menus for custom entities
  4. Add grip hover menus to your own entities
  5. ResetTimes
  6. Resets the AcDbDatabase TDCREATE, TDUPDATE, TDINDWG, and TDUSRTIMER variables.
  7. VisibilityOverrule
  8. Overrule get/set visibility.
  9. BlockTableRecord.SetIsFromOverlayReference
  10. Toggle xref between attachment and overlay.
复制代码
 楼主| 发表于 2010-11-29 00:35:17 | 显示全部楼层
几个很有用的,可惜 ObjectARX only,希望正式发布时能加入到.NET API。
  1. acdbConvertAcDbCurveToGelibCurve
  2. Returns an AcGeCurve3d that is geometrically identical to the AcDbCurve
  3. acdbConvertGelibCurveToAcDbCurve
  4. Returns an AcDbCurve that is geometrically identical to the AcGeCurve3d
  5. acdbAssignGelibCurveToAcDbCurve
  6. Sets the specified AcDbCurve to be geometrically identical to the AcGeCurve3d
复制代码
发表于 2010-11-29 12:35:32 | 显示全部楼层
ObjectARX only的可以考虑用P/Invoke调用,估计下一个版本才会考虑.Net
GMT+8, 2025-6-1 20:20 , Processed in 0.172672 second(s), 23 queries , Gzip On.
