查看: 3575|回复: 14
写扩展数据的问题
发表于 2010-11-24 16:30:00 | 显示全部楼层 |阅读模式
 AddXData(lwPolyLine, i + 1, "polyId");
 //写扩展数据
        public Entity AddXData(Entity ent, Object obj, string regapptablename)
            ObjectId objId = ent.ObjectId;
            Database db = HostApplicationServices.WorkingDatabase;
            Entity retEntity;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                retEntity = (Entity)trans.GetObject(ent.ObjectId, OpenMode.ForWrite);
                RegAppTable apptbl = (RegAppTable)trans.GetObject(db.RegAppTableId, OpenMode.ForWrite);
                if (!apptbl.Has(regapptablename))
                    RegAppTableRecord appTblRcd = new RegAppTableRecord();
                    appTblRcd.Name = regapptablename;
                    apptbl.Add(appTblRcd);
                    trans.AddNewlyCreatedDBObject(appTblRcd, true);
                ResultBuffer resBuf = new ResultBuffer();
                resBuf.Add(new TypedValue((int)DxfCode.ExtendedDataRegAppName, regapptablename));
                resBuf.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, obj));
                ent.XData = resBuf;
                trans.Commit();
            return retEntity;
保存之后关闭再打开,为什么扩展数据里就没有了呢??
发表于 2010-11-24 22:51:00 | 显示全部楼层
子函数里没找到错,这里改下试试
AddXData(lwPolyLine, (i + 1).ToString, "polyId");
 楼主| 发表于 2010-11-25 11:33:00 | 显示全部楼层
TypedValue[] fillist = new TypedValue[] { (new TypedValue((int)DxfCode.Start, "LWPolyline"))};//,new TypedValue(8,"外围轮廓线") };
                SelectionFilter filter = new SelectionFilter(fillist);
                PromptSelectionResult lwPolyRes = ed.SelectAll(filter);
                TypedValue[] fillist1 = new TypedValue[] { (new TypedValue((int)DxfCode.Start, "olyline"))};//, new TypedValue(8, "外围轮廓线") };
                SelectionFilter filter1 = new SelectionFilter(fillist1);
                PromptSelectionResult polyRes = ed.SelectAll(filter1);
                if (lwPolyRes.Status == PromptStatus.OK&&polyRes.Status==PromptStatus.OK)
                    SelectionSet lwPolySet = lwPolyRes.Value;
                    int lwPolyCount = lwPolySet.Count;
                    Polyline lwPolyLine = new Polyline();
                    SelectionSet polySet = polyRes.Value;
                    int polyCount = polySet.Count;
本来想设置断点在第一行的,可是它不执行,直接跑到下面去了,跑就跑呗,执行过的代码还看不到执行结果。是不是vs2005的问题啊???
发表于 2010-11-25 11:39:00 | 显示全部楼层
这个函数好搞笑
 楼主| 发表于 2010-11-25 14:38:00 | 显示全部楼层
搞不懂,不对吗?
发表于 2010-11-25 16:15:00 | 显示全部楼层
哈哈
retEntity == ent;
发表于 2010-11-25 16:22:00 | 显示全部楼层
Entity ent,
你的ent类型是Entity,说明若是已存在的实体,已经打开了,你在这里又再打开,你这一行若没有问题也是多余了,你直接使用ent即可,可能前面是只读打开,那么你升级为可写打开即可,若Entity ent是个新建实体(还没提交到数据库),你这一行应该会报错.
发表于 2010-11-25 16:31:00 | 显示全部楼层
OK,贴个相关的扩展函数,调用方式:
1/简单的例子
    ent.UpgradeOpen(() => ent.ColorIndex = 3) ;
2/较为复杂的例子
                BlockTable.UpgradeOpen
                        BlockTableRecord btr = new BlockTableRecord();
                        btr.Name = name;
                        id = BlockTable.Add(btr);
                        Transaction.AddNewlyCreatedDBObject(btr, true);
        public static void UpgradeOpen<T>(this T obj, Action action) where T : DBObject
            if (obj.IsNotifyEnabled)
                bool b = obj.IsWriteEnabled;
                obj.UpgradeFromNotify();
                action();
                obj.DowngradeToNotify(b);
            else if (obj.IsWriteEnabled)
                action();
            else
                obj.UpgradeOpen();
                action();
                obj.DowngradeOpen();
 楼主| 发表于 2010-11-25 17:02:00 | 显示全部楼层
哦,这样啊.我一直以为
retEntity == ent;
一样呢?我习惯这样写了,现在才知道。谢谢谢谢...我再试试
 楼主| 发表于 2010-11-26 09:36:00 | 显示全部楼层
飞狐,我如果把写过扩展数据的dwg文件,复制一份,再进行操作,那是不是原版和复制版都有扩展数据啊???怎么才能看到它的扩展数据捏
GMT+8, 2025-6-1 19:29 , Processed in 0.192535 second(s), 24 queries , Gzip On.
