查看: 1903|回复: 2
通过csv文件绘图求助
发表于 2010-11-7 21:01:00 | 显示全部楼层 |阅读模式
具体是这样,csv格式表格中每一行有名称,长度和宽度信息
要求用每一行数据绘制一张DXF格式图,图名称为表格中的名称,图纸内容为以表格中长度和宽度绘制的矩形。
举个例子,如果csv中有5行的话就要有5张DXF格式的图纸。希望是lisp写的,本人是菜鸟,刚接触,哪位大侠能帮助小弟一下,定当感激不尽。
发表于 2010-11-8 14:54:00 | 显示全部楼层
  1. (defun c:tt()
  2.   (defun gxl-StrParse (Str Delimiter / SearchStr StringLen return n char nn)
  3. (setq SearchStr Str)
  4. (setq StringLen (strlen SearchStr) nn StringLen)
  5. (setq return '())
  6. (while (> StringLen 0)
  7.   (setq n 1)
  8.   (setq char (substr SearchStr 1 1))
  9.   (while (and (/= char Delimiter) (<= n nn))
  10.    (setq n (1+ n))
  11.    (setq char (substr SearchStr n 1))
  12.   ) ;_ end of while
  13.   (setq return (cons (substr SearchStr 1 (1- n)) return))
  14.   (setq SearchStr (substr SearchStr (1+ n) StringLen))
  15.   (setq StringLen (strlen SearchStr))
  16. ) ;_ end of while
  17.      (if (= " " Delimiter)
  18.        (setq return (vl-remove  "" return))
  19.        )
  20. (reverse return)
  21. )
  22.   (setq fn (getfiled "请输入文件名 :" "" "csv" 4))
  23.   (setq f (open fn "r"))
  24.   (while (setq zc (read-line f))
  25.     (setq zc (GXL-STRPARSE zc ","))
  26.     (setq fname (car zc)
  27.    L (cadr zc)
  28.    w (caddr zc)
  29.    )
  30.     (command "_.rectang"  '(0 0 0) (strcat "@" l "," w))
  31.     (command "_.dxfout" fname "")
  32.     (command "erase" "all" "")
  33.     )
  34. (close f)
  35.   )
发表于 2010-11-8 22:37:00 | 显示全部楼层
程序要在空白图中运行
游客,本帖隐藏的内容需要发帖数高于 2 才可浏览,你当前发帖数只有 0
GMT+8, 2025-5-1 17:34 , Processed in 0.184327 second(s), 24 queries , Gzip On.
