查看: 3955|回复: 1
[图元] 扩展函数之图元操作
发表于 2010-11-2 10:31:00 | 显示全部楼层 |阅读模式
VS2008提供的扩展方法可以让我们简单的给Autodesk补漏(汗)
下面是些简单的例子,注释有时间再加哈
  1. using System.Collections;
  2. using System.Collections.Generic;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.Geometry;
  5. namespace TlsCad.ExtendMethods
  6. {
  7.     public static class EntityEx
  8.     {
  9.         public static IEnumerable<Vertex> GetVertexs<T>(this T ent, Transaction tr) where T : Entity, IEnumerable
  10.         {
  11.
  12.             foreach (ObjectId id in ent)
  13.             {
  14.                 yield return (Vertex)tr.GetObject(id, OpenMode.ForRead);
  15.             }
  16.         }
  17.         public static IEnumerable<Vertex> GetVertexs<T>(this T ent, Transaction tr, OpenMode mode) where T : Entity, IEnumerable
  18.         {
  19.             foreach (ObjectId id in ent)
  20.             {
  21.                 yield return (Vertex)tr.GetObject(id, mode);
  22.             }
  23.         }
  24.         public static Extents3d GetExtents(this IEnumerable<Entity> ents)
  25.         {
  26.             Extents3d ext = new Extents3d();
  27.             foreach (Entity ent in ents)
  28.             {
  29.                 ext.AddExtents(ent.GeometricExtents);
  30.             }
  31.             return ext;
  32.         }
  33.         public static void Move(this Entity ent, Point3d from, Point3d to)
  34.         {
  35.             ent.TransformBy(Matrix3d.Displacement(to - from));
  36.         }
  37.         public static void Rotation(this Entity ent, Point3d center, double angle, Vector3d normal)
  38.         {
  39.             ent.TransformBy(Matrix3d.Rotation(angle, normal, center));
  40.         }
  41.         public static void Rotation(this Entity ent, Point3d center, double angle)
  42.         {
  43.             ent.TransformBy(Matrix3d.Rotation(angle, Vector3d.ZAxis.TransformBy(ent.Ecs) , center));
  44.         }
  45.         public static void Mirror(this Entity ent, Point3d pt1, Point3d pt2)
  46.         {
  47.             ent.TransformBy(Matrix3d.Mirroring(new Line3d(pt1, pt2)));
  48.         }
  49.         public static void Mirror(this Entity ent, Plane plane)
  50.         {
  51.             ent.TransformBy(Matrix3d.Mirroring(plane));
  52.         }
  53.         public static void Mirror(this Entity ent, Point3d ptBase)
  54.         {
  55.             ent.TransformBy(Matrix3d.Mirroring(ptBase));
  56.         }
  57.         public static void ValidateMirror(this DBText txt)
  58.         {
  59.             if (!txt.Database.Mirrtext)
  60.             {
  61.                 txt.IsMirroredInX = false;
  62.                 txt.IsMirroredInY = false;
  63.             }
  64.         }
  65.     }
  66. }
发表于 2015-7-28 10:07:13 | 显示全部楼层
赞..     学习
GMT+8, 2025-5-1 21:25 , Processed in 0.170662 second(s), 24 queries , Gzip On.
