查看: 2026|回复: 4
[求助]解锁dim标注数值,怎么编写?
发表于 2010-10-28 09:15:00 | 显示全部楼层 |阅读模式
以下是锁定dim标注数值的lsp,可作参考?
(defun C:TT1 (/ ENT ENTT OBJ)
  (setq ENT (nentselp "\n选取标註: "))
  (if (and ENT
    (= "DIMENSION"
       (cdr (assoc 0 (entget (setq ENTT (last (last ENT))))))
      (vlax-for OBJ
      (vla-item
        (vla-get-blocks
   (vla-get-activedocument (vlax-get-acad-object))
        (cdr (assoc 2 (entget ENTT)))
 (if (equal (vla-get-objectname OBJ) "AcDbMText")
   (setq TXT (vla-get-textstring OBJ))
      (vla-put-textoverride
 (vlax-ename->vla-object ENTT)
 TXT
发表于 2010-10-28 22:26:00 | 显示全部楼层
(defun c:TRDIM (/ ent pt1 pt2 pt3 pt9 ent1)
 (setq ent (entget (car (entsel))))
           ;選擇線段圖元,將其描述串列置於ent
 (setq pt1 (cdr (assoc 42 ent)))
           ;取尺寸線標註長度(描述串列)置於pt1
; (setq pt2 (cdr (assoc 1 ent)))
           ;取尺寸線標註長度修改後(描述串列)置於pt2
; (setq pt3 (cdr (assoc 3 ent)))
           ;取尺寸線標註長度修改後(描述串列)置於pt3
 (setq pt9 "")
 (setq ent1 (subst (cons 1 pt9) (assoc 1 ent) ent))
         ;以新終點座標點對(dotted pair)替換ent中的舊終點座標點對
 (entmod ent1) ;更新圖形資料庫中該線段的資料
 (prompt " ------ <<c:TRDIM>>------")
 (prin1)
发表于 2010-10-28 22:36:00 | 显示全部楼层
(defun C:TT2 (/ ENT ENTT OBJ)
  (setq ENT (nentselp "\n选取标注: "))
  (if (and ENT
    (= "DIMENSION"
      (vlax-for OBJ
      (vla-item
        (vla-get-blocks
; TXT   将TXT改成""
 楼主| 发表于 2010-10-29 09:56:00 | 显示全部楼层
ok了,感谢楼上的热心!
发表于 2011-4-7 21:57:21 | 显示全部楼层
两位的都是经典的好程序,不知能否改成多选呢?
用于局部放大!
GMT+8, 2025-5-25 22:41 , Processed in 0.162358 second(s), 24 queries , Gzip On.
