查看: 7975|回复: 16
面积计算程序原代码!
发表于 2003-7-9 23:46:00 | 显示全部楼层 |阅读模式
  1. Sub sarea() '计算多边形面积程序
  2. On Error GoTo err
  3. Dim areaobj As AcadLWPolyline
  4. Dim sset As AcadSelectionSet
  5. Dim minpnt As Variant
  6. Dim maxpnt As Variant
  7. Dim areains(0 To 2) As Double '
  8. Dim txtarea As String
  9. Dim txtins As String
  10. Dim ms As String
  11. Dim txtobj As AcadText
  12. Dim us1 As Integer '比例尺
  13. us1 = ThisDrawing.GetVariable("userr1") '取得比例尺
  14. For i = 0 To ThisDrawing.SelectionSets.Count - 1
  15. ThisDrawing.SelectionSets.Item(i).Clear
  16. ThisDrawing.SelectionSets.Item(i).Delete
  17. Next
  18. Set sset = ThisDrawing.SelectionSets.Add("sarea")
  19. sset.SelectOnScreen
  20. If sset.Item(0).Closed = False Then
  21. MsgBox "图形不闭合,请检查!"
  22. Exit Sub
  23. End If
  24. sset.Item(0).GetBoundingBox minpnt, maxpnt
  25. areains(0) = (minpnt(0) + maxpnt(0)) / 2
  26. areains(1) = (minpnt(1) + maxpnt(1)) / 2
  27. areains(2) = 0
  28. Select Case us1
  29. Case 500
  30. txtarea = sset.Item(0).area / 4
  31. Case 1000
  32. txtarea = sset.Item(0).area
  33. Case 2000
  34. txtarea = sset.Item(0).area * 2
  35. Case Else
  36. MsgBox "你的比例尺不在可计算之列,请检查你的比例尺"
  37. Exit Sub
  38. End Select
  39. ms = Format(txtarea / 666.6666, "#0.000")
  40. txtarea = Format(txtarea, "#0.000")
  41. txtins = "S=" & txtarea & "平方米=" & ms & "亩"
  42. Set txtobj = ThisDrawing.ModelSpace.AddText(txtins, areains, 5)
  43. txtobj.Color = acGreen
  44. '*******************************
  45. Dim hatchobj As AcadHatch
  46. Dim pname As String '阴影名称
  47. Dim pype As Long '阴影类型
  48. pname = "ANSI31"
  49. ptype = 0
  50. Set hatchobj = ThisDrawing.ModelSpace.AddHatch(ptype, pname, True)
  51. Dim outloop(0 To 0) As AcadEntity
  52. Set outloop(0) = sset.Item(0)
  53. hatchobj.AppendOuterLoop (outloop)
  54. hatchobj.Evaluate
  55. err:
  56. Exit Sub
  57. End Sub
太给力了,。,请问能体现加减乘除计算规则吗  发表于 2011-12-28 22:21
发表于 2003-7-10 09:56:00 | 显示全部楼层
为什么不用cad的查询命令?现成的呀,有时只不过要把封闭区域变成面域而已!
发表于 2003-7-10 12:38:00 | 显示全部楼层
非常感谢myfreemind老师,对于你的慷慨我很是感动,再次感谢。希望日后还能多多指点。
只是我不懂VBA,看来回去要研究一下了。
 楼主| 发表于 2003-7-10 23:15:00 | 显示全部楼层
不谢,一起提高!
 楼主| 发表于 2003-7-10 23:17:00 | 显示全部楼层
是的,可以实现!
目的是为了学习程序!
发表于 2003-12-17 16:48:00 | 显示全部楼层
实在是感谢
发表于 2003-12-28 23:43:00 | 显示全部楼层
very good
发表于 2004-1-15 19:01:00 | 显示全部楼层
这是个好东西!送花一朵!
我研究研究!
发表于 2004-1-15 19:02:00 | 显示全部楼层
刚才忘记了!你怎么又变成蒙面侠了?
 楼主| 发表于 2004-1-15 19:45:00 | 显示全部楼层
chb801发表于2004-1-15 19:02:00刚才忘记了!你怎么又变成蒙面侠了?
升级了,呵呵
GMT+8, 2025-5-1 12:39 , Processed in 0.191143 second(s), 26 queries , Gzip On.
