查看: 1706|回复: 3
加入尺寸类型选择,执行代码
发表于 2010-10-10 21:35:00 | 显示全部楼层 |阅读模式
路过的高手,帮帮忙啊!这个程序谁能帮忙加个尺寸类型的选择啊,
;;;修改属性值
(defun c:SZ (/ e1)
(setvar "cmdecho" 0)(setvar "pickbox" 21)
(setq e1 (entget (car (setq s1 (entsel "选择编辑对象:")))))
(if (= (cdr (assoc 0 e1)) "TEXT") (command "DDEDIT" s1))
(if (= (cdr (assoc 0 e1)) "MTEXT") (command "DDEDIT" s1))
(if (= (cdr (assoc 0 e1)) "INSERT") (command "DDATTE" s1))(princ))
就是说如果我选择的类型是“尺寸”哦:  '((0 . "DIMENSION"))  ,  那么我就执行以下这些代码:
(defun TDZ (/ nqz nhz QZ HZ )
(SETQ DS (getstring (strcat "\n 输入替代值:" )))
(if (= DS nil ) (command "dim1" "new" (strcat DS "<>{}{}") e1 ""))
(if (/= DS nil ) (command "dim1" "new" (strcat DS "{}{}") e1 ""))
(princ))
发表于 2010-10-11 11:26:00 | 显示全部楼层
(defun c:SZ (/ e1)
  (if (= (cdr (assoc 0 e1)) "DIMENSION")
    (TDZ)
 楼主| 发表于 2010-10-11 12:17:00 | 显示全部楼层
谢谢啦
发表于 2011-10-22 19:49:09 | 显示全部楼层
淡定淡定淡淡的
GMT+8, 2025-5-1 15:39 , Processed in 0.169864 second(s), 23 queries , Gzip On.
