楼主: santalin
[原创] █ 直接将VBForm转DCL 程序【VB2DCL】【含截图及演示】█
发表于 2010-10-7 15:29:00 | 显示全部楼层
下载学习学习
发表于 2010-10-7 15:30:00 | 显示全部楼层
下载学习学习
 楼主| 发表于 2010-10-7 15:39:00 | 显示全部楼层
sachindkini发表于2010-10-7 13:46:00 dear sir   some error found creating the lisp Command:; error: syntax error Command:Command: tt; error: no function definition: LSD_FORM1_CMDACTION
 Let me see
 I'll tell u why after testing the program
 楼主| 发表于 2010-10-7 15:47:00 | 显示全部楼层
 Do u check "Define button action"?
 You lost the function which name is "LSD_FORM1_CMDACTION"
 Maybe u change the name  of function or u delete the function
 If u don't want to define the action of these button in the VB form
 Just delete the line below in the function of "(defun c:tt()" in the lsp file
 that is:
 (lsd_Form1_cmdAction) ;Define button action
 楼主| 发表于 2010-10-7 15:55:00 | 显示全部楼层
If that way doesn't work,Please upload you VB FORM
 楼主| 发表于 2010-10-7 16:11:00 | 显示全部楼层
sachindkini发表于2010-10-7 13:46:00 dear sir help.chm not found
  As I don't have enough time to write the help file,"help.chm" doesn't exsist.
  I made a video demo uploaded to my network disk
  Just Chinese interpretation in the demo
发表于 2010-10-7 16:47:00 | 显示全部楼层
支持一下
发表于 2010-10-7 16:48:00 | 显示全部楼层
这个程序的实现,关键就在于递归调用
 下面是程序关键流程框图及伪代码(你可以根据这个框图写成任何语言的程序):
发表于 2010-10-8 10:26:00 | 显示全部楼层
好程序啊!要是有vba等直接转换vlisp就更好了!
发表于 2010-10-8 11:08:00 | 显示全部楼层
楼主,是用vc 还是net写的怎么是exe文件的?
GMT+8, 2025-12-12 06:52 , Processed in 0.153969 second(s), 19 queries , Gzip On.
