查看: 3354|回复: 2
[求助]请求完善下面批量交点打断程序,1、可以打断PLINE线,2、内部断线可以自动删
发表于 2010-9-25 14:38:00 | 显示全部楼层 |阅读模式
[求助]请求完善下面批量交点打断程序,1、可以打断PLINE线,2、内部断线可以自动删除.[br]
;;;;;;;;;批量交点打断程序,by:fools
;;支持line arc circle ELLIPSE
(defun c:MB (/ elist ssg n t0)
(VL-LOAD-COM)
(prompt "\n支持line arc circle ELLIPSE!")
(setq t0 (xdl-getutime))
(if (setq ssg (ssget '((0 . "line,arc,circle,ellipse"))))
    (vlax-for obj (vla-get-activeselectionset
      (vla-get-activedocument (vlax-get-acad-object))
      (setq elist (cons obj elist)) ; ssg->elist
(DoEntMake (InterSort (ssinter elist)))
(princ (strcat "\n*****找到交点"
   (itoa n)
   "个,交点断开操作共耗时"
   (rtos (- (xdl-getutime) t0) 2 3)
   "秒。*****"
;;求交点集函数-nth
;;经过测试,nth函数仅比assoc函数快一点点。
;;故此函数也可取消i,j变量,直接使用assoc函数
(defun ssinter (el / el1 obj1 obj2 ipts pts list1 outlst i j)
(setq outlst (mapcar 'list el)
i      -1    ;obj1位置指针
n      0    ;交点数计数器
(while el
    (setq obj1 (car el)
   list1 (nth (setq i (1+ i)) outlst) ;obj1已有的交点列表
   el (cdr el)
   el1 el
   j i    ;obj2位置指针
    (while el1
      (setq obj2 (car el1)
     el1 (cdr el1)
     j (1+ j)
      ;;取交点
      (if (and (setq ipts (vla-intersectwith obj1 obj2 0))
        (setq ipts (vlax-variant-value ipts))
        (> (vlax-safearray-get-u-bound ipts 1) 0)
   (setq ipts (vlax-safearray->list ipts)
   pts '()   ;obj1,obj2交点临时列表变量
   (while (> (length ipts) 0)
     (setq pts (cons (list (car ipts)
       (cadr ipts)
       (caddr ipts)
        pts
    ipts (cdddr ipts)
   (setq list1 (append list1 pts)
      ;存obj1交点表,循环结束后再更新
   n     (+ n (length pts)) ;交点计数累加
   ;;obj2的交点列表立即更新
   (setq
     outlst (subst (append (nth j outlst) pts)
     (nth j outlst)
     outlst
    ;;当obj1存在交点,且非封闭曲线,添加两端点
    (if (and (cdr list1) (not (vlax-curve-isClosed obj1)))
     (list (vlax-curve-getEndPoint obj1))
     (list (vlax-curve-getStartPoint obj1))
    (setq outlst (subst list1 (nth i outlst) outlst))
      ;更新obj1交点列表
outlst
;;点集排序及删除重复点函数
(defun InterSort (el / obj1 pts plst outlst)
(setq outlst '())    ;empty list
(foreach item el
    (setq obj1 (car item)
   pts (cdr item)
   plst '()    ;empty list
    (if pts     ;若无交点,则不修改该实体
;;交点排序,列表为逆序
(setq
   pts (vl-sort
   pts
   (function (lambda (p1 p2)
       (< (vlax-curve-getParamAtPoint obj1 p1)
          (vlax-curve-getParamAtPoint obj1 p2)
;;剔除重复点并将列表顺序转正
(foreach p pts
   (if plst
     (if (not (equal p (car plst) 0.00001))
       (setq plst (cons p plst))
;;闭合曲线需再添加首个交点以使新实体完全封闭
(if (vlax-curve-isClosed obj1)
   (setq plst (cons (last plst) plst))
(setq plst   (cons (vlax-vla-object->ename obj1) plst)
       outlst (cons plst outlst)
outlst
;;调用entmake生成新实体
(defun DoEntMake (el / obj objlst objname objcen objratio objaxis)
(foreach e el
    (setq obj   (car e)
   objlst (entget obj)
   objlst (vl-remove (assoc -1 objlst) objlst) ;去除图元名
   objlst (vl-remove (assoc 330 objlst) objlst) ;去除id
   objlst (vl-remove (assoc 5 objlst) objlst) ;去除句柄
   objname (cdr (assoc 0 objlst))
    (cond
      ((= objname "LINE")
       (repeat (- (length e) 2)
(setq e (cdr e))
(setq
    objlst (subst (cons 10 (car e)) (assoc 10 objlst) objlst)
(setq objlst
   (subst (cons 11 (cadr e)) (assoc 11 objlst) objlst)
(entmake objlst)
       (entdel obj)
      ((= objname "CIRCLE")
       (setq objcen (cdr (assoc 10 objlst)))
       (setq objlst (subst (cons 0 "ARC") (assoc 0 objlst) objlst))
       (setq objlst (append objlst
       (list (cons 100 "AcDbArc")
      (cons 50 0.0)
      (cons 51 0.0)
(setq e (cdr e))
(setq objlst (subst (cons 50 (angle objcen (cadr e)))
        (assoc 50 objlst)
        objlst
(setq objlst (subst (cons 51 (angle objcen (car e)))
        (assoc 51 objlst)
        objlst
(entmake objlst)
       (entdel obj)
      ((= objname "ARC")
(setq e (cdr e))
        (assoc 50 objlst)
        objlst
        (assoc 51 objlst)
        objlst
(entmake objlst)
       (entdel obj)
      ((= objname "ELLIPSE")
       ;;椭圆圆心
       ;;相对于中心的长轴矢量
       (setq objaxis (cdr (assoc 11 objlst)))
       ;;短轴与长轴的比例
       (setq objratio (cdr (assoc 40 objlst)))
(setq e (cdr e))
(setq objlst
   (subst
    (cons 41
    (pt->param (cadr e) objcen objaxis objratio)
    (assoc 41 objlst)
    objlst
(setq objlst
   (subst
    (cons 42
    (pt->param (car e) objcen objaxis objratio)
    (assoc 42 objlst)
    objlst
(entmake objlst)
       (entdel obj)
;;计算耗时
(defun xdl-getutime ()
(* 86400 (getvar "tdusrtimer"))
;;求椭圆曲线参数
(defun pt->param (pt cen axis ratio / ang param)
(setq ang (- (angle cen pt) (angle '(0. 0. 0.) axis)))
(cond ((= (cos ang) 0.0)   ;防止分母cos为零出错
(if (> (sin ang) 0.0)
    (setq param (* 0.5 PI))
    (setq param (* 1.5 PI))
((= (sin ang) 0.0)
(if (> (cos ang) 0.0)
    (setq param 0.0)
    (setq param PI)
(T
(setq param (atan (/ (sin ang) (* (cos ang) ratio))))
(if (< (cos ang) 0.0)
    (setq param (+ pi param))
param
发表于 2017-11-14 12:21:30 | 显示全部楼层
你这个程序完善了吗?
发表于 2018-1-6 22:12:24 | 显示全部楼层
恩 ,思路不错,我看看能不能重写
GMT+8, 2025-5-1 12:08 , Processed in 0.214780 second(s), 23 queries , Gzip On.
