帖子
查看: 3007|回复: 10
请帮忙解决空输入的问题
发表于 2010-9-10 12:09:00 | 显示全部楼层 |阅读模式
我有个程序代码如下:
(defun c:TQ (/ ifdimt BL SS SS1   )
(setvar "cmdecho" 0)
(setq scal (getvar "dimscale"))
(setq qz "1:")
(setq BL (getstring (strcat "\n请确认或输入图幅比例值 (默认值<" (rtos scal 2) ">):")))
(if (NULL BL)(setq BL (getvar "dimscale")))
(if (= BL nil )
(setq BL scal
      inspoint (getpoint "\n请指定放置点: ")))
(setq TBL (strcat qz BL ))(if (NULL qz)(setq qz (getvar "dimscale")))
(command "mtext" x2 "j" "TL" "@-70,12" TBL "" "EXPLODE" (ENTLAST))
(command "osnap" "end,mid,int,NOD,INS,cen,per,TAN,NEA,QUI,APP,EXT,PAR");捕捉全部
(setq ss (ssget))(if (NULL SS)(EXIT))
(command "_cutclip"  ss "" "_pasteblock" "SCALE" scal inspoint ) (princ))
现在就是想要实现 当出现提示"\n请确认或输入图幅比例值 (默认值<" (rtos scal 2) ">):" 时,
如果我此时直接回车或空格,那么"mtext" 文字写出来是 1:"(默认值<" (rtos scal 2) ">)", 缩放时scal用默认值
如果我此时输入其它数据,那么"mtext" 文字写出来是 1:"输入值", 缩放时scal用输入值
望高手赐教
发表于 2010-9-10 15:53:00 | 显示全部楼层
(setq qz "1:")
(initget 7 "  ")
(setq Bl (getreal (strcat "\n请确认或输入图幅比例值 (默认值<" (rtos scal 2) ">):")))
(if (= BL "") (setq BL scale))
 楼主| 发表于 2010-9-10 18:29:00 | 显示全部楼层
首先,感谢Gu_xl的热心帮助!!!!
我测试了下还一样出现如下错误:
1如果我直接回车或空格:
请确认或输入图幅比例值 (默认值<1.0000>):
请指定插入点: Error: 参数类型错误: stringp nil
2如果我输入数值:
请确认或输入图幅比例值 (默认值<1.0000>):3
请指定插入点: Error: 参数类型错误: stringp 3.0
目的:插入一个图块,中途出现输入比例值并使用这个值缩放,
如果我没输入(即直接回车或空格)则采用当前标注比例值进行缩放,
但是我还要在特定位置打字表示 1:图幅比例值 (这个问题能解决么?)
到现在还用这个笨办法:(代码如下)
;;;画图框(自动插块,一定要在配置文件中添加支持搜索路径才能实现)
(defun c:TQ (/ ifdimt BL SS SS1   )(setvar "cmdecho" 0)
(command "insert" "ATydh"   x4 "" "" "" "")
(command "insert" "A附加栏" x1 "" "" "" )
(command "insert" "标题栏0" x2 "" "" "" )
(command "style" "PC_TEXTSTYLE" "" "" "" "" "" "" )
(setq qz "1:")
(if (= BL nil )(setq BL scal
                inspoint (getpoint "\n请指定插入点: ")))
(if (NULL BL)(command "mtext" x2 "j" "TL" "@-70,12" (strcat qz (rtos scal 2) ) "" "EXPLODE" (ENTLAST)))
(if (/= NULL BL)(command "mtext" x2 "j" "TL" "@-70,12" TBL "" "EXPLODE" (ENTLAST)))
(princ))
现在我就是想解决当我没输入时也写字“1:默认值(getvar "dimscale")))”
而不是 “1:”
发表于 2010-9-10 20:32:00 | 显示全部楼层
没看你的程序,根据你的错误提示,BL响应应为字串,修改如下:
(setq qz "1:")
(initget 7 "  ")
(if (= BL "") (setq BL (rtos scale 2))(setq BL (rtos BL 2)))
(setq inspoint (getpoint "\n请指定放置点: ")))
 楼主| 发表于 2010-9-11 06:22:00 | 显示全部楼层
很高兴看到Gu_xl兄台的再次回复
再次感谢Gu_xl兄台!
复制你的改动进去后,一加载就出现:
现在我就是想解决当我没输入时也写字显示“1:默认值(getvar "dimscale")))”
而不是显示 “1:
这个有难度吗?
发表于 2010-9-11 09:33:00 | 显示全部楼层
游客,本帖隐藏的内容需要发帖数高于 10 才可浏览,你当前发帖数只有 0
 楼主| 发表于 2010-9-11 11:41:00 | 显示全部楼层
好了!正是我想要的结果!感谢二位的热心帮助[em200]
发表于 2013-1-1 02:51:17 | 显示全部楼层
谢谢楼主分享啊
发表于 2013-1-1 02:52:32 | 显示全部楼层
谢谢楼主分享啊
发表于 2013-1-1 02:55:31 | 显示全部楼层
谢谢楼主分享啊
GMT+8, 2025-6-4 15:36 , Processed in 0.180794 second(s), 24 queries , Gzip On.
