查看: 2465|回复: 1
创建块后无法预览
发表于 2010-9-6 10:52:00 | 显示全部楼层 |阅读模式
我在代码里通过选择集创建一个块,创建后在窗体中预览这个块,但是无法预览,而调用cad自带的block命令创建块后就可以预览,why?
下面是我创建块的代码
   ublic Shared Function CreateBlock1(ByVal blackName As String)
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Dim blockImg As Drawing.Bitmap = Nothing '需要返回的Img对象
        Dim lock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
        Using lock
            Dim blockId As ObjectId = ObjectId.Null               '用于返回所创建的块的对象Id
            Dim record As BlockTableRecord = New BlockTableRecord()  '创建一个BlockTableRecord类的对象,表示所要创建的块
            record.Name = blackName                         '设置块名
            record.Origin = New Point3d(0, 0, 0)              '设置块的基点
            Dim trans As Transaction = db.TransactionManager.StartTransaction()
            Using trans
                Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
                If bt.Has(record.Name) = False Then
                    Dim res As PromptSelectionResult = ed.GetSelection() '选择对象
                    If res.Status = PromptStatus.OK Then
                        '  foreach (ObjectId id in res.Value.GetObjectIds())
                        Dim id As ObjectId = ObjectId.Null
                        For Each id In res.Value.GetObjectIds()
                            Dim ent As Entity = trans.GetObject(id, OpenMode.ForWrite)
                            Dim NewEnt As Entity = ent.Clone()
                            record.AppendEntity(NewEnt)
                        Next
                        bt.Add(record)                          '在块表中加入块
                        trans.AddNewlyCreatedDBObject(record, True) '通知事务处理
                        blockImg = BlockThumbnailHelper.GetBlockThumbanail(record.ObjectId)
                    End If
                End If
                trans.Commit()
            End Using
        End Using
        Return Nothing
发表于 2011-9-27 22:47:39 | 显示全部楼层
是不是你插入的太小了看不到啊。有这个可能
GMT+8, 2025-5-25 05:17 , Processed in 0.140194 second(s), 23 queries , Gzip On.
