查看: 2053|回复: 4
[求助] 求帮忙改程序!!
发表于 2010-9-3 11:26:00 | 显示全部楼层 |阅读模式
朋友给了一个LISP小程序,可以根据命令自动将实体标注等归到指定层,但是程序只对CAD自有命令有用,对其他加载的程序命令不起作用,
哪位高手能帮忙改下,使它能识别自编程序命令,比如通过一个自编程序自动画个钢型才的剖面,输入命令后CAD 就自动跳掉指定的图层,如没有此图层则自动建立,画完以后再跳回命令前的图层,原程序如下:
(defun xlr-autolayer ()
;  (setvar "cmdecho" 0)
;  (if (null (tblsearch "layer" "text"))
;    (set_layer_list "text" 3 "continuous")
;  (if (null (tblsearch "layer" "dim"))
;    (set_layer_list "dim" 3 "continuous")
  (vl-load-com)
  ;; 图层初始化列表 内容:commands layers color linetype plottable
  (setq *doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq *lays (vla-get-layers *doc))
  (setq *laylst
  (list (list "DIMANGULAR" "DIM-MQ" 3 "continuous" T)
        (list "DIMALIGNED" "DIM-MQ" 3 "continuous" T)
        (list "DIMBASELINE" "DIM-MQ" 3 "continuous" T)
        (list "DIMCENTER" "DIM-MQ" 3 "continuous" T)
        (list "DIMCONTINUE" "DIM-MQ" 3 "continuous" T)
        (list "DIMDIAMETER" "DIM-MQ" 3 "continuous" T)
        (list "DIMLINEAR" "DIM-MQ" 3 "continuous" T)
        (list "DIMORDINATE" "DIM-MQ" 3 "continuous" T)
        (list "DIMRADIUS" "DIM-MQ" 3 "continuous" T)
        (list "QDIM" "DIM-MQ" 3 "continuous" T)
        (list "QLEADER" "DIM-MQ" 3 "continuous" T)
        (list "BHATCH" "1-填充" 9 "continuous" T)
        (list "HATCH" "1-填充" 9 "continuous" T)
        (list "XLINE" "defpoints" 8 "continuous" T)
        (list "mleader" "text" 3 "continuous" T)
  (setq OldLayer nil)
  (setq *cmdlst (mapcar 'strcase (mapcar 'car *laylst)))
  (mapcar '(lambda (x) (vlr-command-reactor nil x))
   (list '((:vlr-commandWillStart . xlr-start))
  '((:vlr-commandEnded . xlr-end))
  '((:vlr-commandCancelled . xlr-cancel))
  (vlr-editor-reactor
    nil
    '((:vlr-commandwillstart . xlr-edit))
(defun xlr-edit (CALL CALLBACK /)
  (foreach N *laylst
    (if (= (strcase (car CALLBACK)) (strcase (car N)))
     ; 命令反应器返回信息如果与设置的命令相同.
      (progn    ;建立图层
(apply 'xsetlays (cdr N))
     ;(setvar "CLAYER" (cadr N));设为当前层.
(defun xlr-start (calling-reactor xlr-startInfo /)
  (foreach N *laylst
    (if (= (strcase (car xlr-startInfo)) (strcase (car N)))
      (progn    ;建立图层
(defun xlr-end (calling-reactor xlr-endInfo / cmd)
  (setq cmd (car xlr-endInfo))
  (if (member cmd *cmdlst)
    (if (/= oldlayer nil)
           (setvar "CLAYER" OldLayer)
           (setq OldLayer nil)
(defun xlr-cancel (calling-reactor xlr-cancelInfo / cmd)
  (setq cmd (car xlr-cancelInfo))
           (setq OldLayer nil)
(defun xsetlays (LAY-NAM COLOR LTYPE plotk / LAYOBJ LTYPESOBJ)
  (if (tblobjname "layer" LAY-NAM)
      (if (/= (strcase (getvar "CLAYER"))
       (strcase LAY-NAM)
(setq OldLayer (getvar "CLAYER"))
   (if (= oldlayer nil)
     (setq OldLayer LAY-NAM)
      (setvar "CLAYER" lay-nam)
    (progn    ;添加图层.
      (vl-catch-all-error-p
(vl-catch-all-apply 'vla-add (list *lays LAY-NAM))
      (setq LAYOBJ (vla-item *lays LAY-NAM))
      (if (not (tblobjname "ltype" LTYPE)) ;添加线型.
   (setq LTYPESOBJ (vla-get-linetypes *doc))
   (vla-load LTYPESOBJ LTYPE (findfile "acad.lin"))
     ;>>> 要加强,在多个*.lin寻找
   (vlax-release-object LTYPESOBJ)
      )     ;解冻(如冻结),解锁,设图层为当前,设图层颜色,可打印特性.
      (vla-put-layeron layobj :vlax-true)
      (vla-put-lock layobj :vlax-false)
      (if (= (strcase (getvar "CLAYER")) (strcase lay-nam)) ;解冻.
(vla-put-freeze layobj :vlax-false)
      (vla-put-color layobj color)
      (vla-put-linetype layobj LTYPE)
      (vla-put-plottable
layobj
(if plotk
   :vlax-true
   :vlax-false
(xlr-autolayer)    ;加载启动!
(princ "\n ----命令图层反应器已加载----")
发表于 2010-9-3 19:55:00 | 显示全部楼层
这个没法改,提供的资料太少。下面是程序中命令与图层对应的数据表,可参照修改。
(setq *laylst
 '(("DIMANGULAR" "DIM-MQ" 3 "continuous" T)
   ("DIMALIGNED" "DIM-MQ" 3 "continuous" T)
   ("DIMBASELINE" "DIM-MQ" 3 "continuous" T)
   ("DIMCENTER" "DIM-MQ" 3 "continuous" T)
   ("DIMCONTINUE" "DIM-MQ" 3 "continuous" T)
   ("DIMDIAMETER" "DIM-MQ" 3 "continuous" T)
   ("DIMLINEAR" "DIM-MQ" 3 "continuous" T)
   ("DIMORDINATE" "DIM-MQ" 3 "continuous" T)
   ("DIMRADIUS" "DIM-MQ" 3 "continuous" T)
   ("QDIM" "DIM-MQ" 3 "continuous" T)
   ("QLEADER" "DIM-MQ" 3 "continuous" T)
   ("BHATCH" "1-填充" 9 "continuous" T)
   ("HATCH" "1-填充" 9 "continuous" T)
   ("XLINE" "defpoints" 8 "continuous" T)
   ("mleader" "text" 3 "continuous" T)
第一列参数为命令名
第二列参数为图层名
第三列是颜色
第四列是线型
 楼主| 发表于 2010-9-4 10:18:00 | 显示全部楼层
这个我知道,上面的是我自己该的,这些都是 CAD 自带命令,对于自编命令就没用。
发表于 2010-9-4 11:08:00 | 显示全部楼层
试下用vlax-add-cmd将你的命令添加到ACAD内置命令集中
 楼主| 发表于 2010-9-7 20:40:00 | 显示全部楼层
楼上的命令 没什么反应么?
GMT+8, 2025-5-1 19:53 , Processed in 0.182950 second(s), 23 queries , Gzip On.
