查看: 1694|回复: 4
[求助][讨论]这段连接线的代码为什么会出现如下的错误窗口
发表于 2010-8-11 21:52:00 | 显示全部楼层 |阅读模式
这段连接线的代码为什么会出现如下的错误窗口,框选连接时才会出现,点选不会。
Sub uniteSS()
  'On Error Resume Next
  Dim ssetObj As AcadSelectionSet
  Set ssetObj = CreateSelectionSet("uniteSS")
  Dim fType, fData
  BuildFilter fType, fData, -4, "<or", 0, "line", 0, "LWPolyline", -4, "or>"
  '屏选直线或多段线
  ssetObj.SelectOnScreen fType, fData
  Dim i As Integer
  If ssetObj.Count <= 1 Then
    ThisDrawing.Utility.Prompt "选择的线少于两个,退出命令。"
    Exit Sub
  End If
  Dim line1 As Object
  Dim line2 As Object
  Set line1 = ssetObj(0)
  Dim pd As Boolean
  For i = 1 To ssetObj.Count
    Set line2 = ssetObj(i)
    '连接线
    pd = unite2Line(line1, line2)
    '如果连接不成功,则退出命令。
    If Not pd Then ssetObj.Delete: Exit Sub
  Next
  ssetObj.Delete
End Sub
Sub uniteline()
  '取得线
  Dim line1 As Object
  Dim line2 As Object
  Dim pt1, pt2, pt3, pt4, basePnt As AcadEntity
  Dim lpt1, lpt2 As Variant
  gwGetEntity line1, basePnt, "请选择第一根直线或多段线:", "AcDbLine", "AcDbPolyline"
  If line1 Is Nothing Then
    ThisDrawing.Utility.Prompt "用户取消,退出命令。"
    Exit Sub
  End If
  gwGetEntity line2, basePnt, "请选择第二根直线或多段线:", "AcDbLine", "AcDbPolyline"
  If line2 Is Nothing Then
    Exit Sub
  End If
  '连接线
  unite2Line line1, line2
End Sub
Function unite2Line(ByRef line1 As Object, ByVal line2 As Object) As Boolean
  '连接线函数,连接后的线返回到变量line1中,如果连接成功,unite2Line返回true,否则为false
  unite2Line = False
  If line1.Handle = line2.Handle Then
    ThisDrawing.Utility.Prompt "选择的是同一直线或多段线,退出命令。"
    Exit Function
  End If
  getLinePoint line1, pt1, pt2
  getLinePoint line2, pt3, pt4
  Dim A1, A2, A3 As Double
  Dim maxdi As Double
  A1 = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2)
  A2 = ThisDrawing.Utility.AngleFromXAxis(pt3, pt4)
  A3 = ThisDrawing.Utility.AngleFromXAxis(pt1, pt3)
  '判断四点是否共线
  If Abs(A1 - A2) < 0.0000001 And (Abs(A1 - A3) < 0.0000001 Or Abs(Abs(A1 - A3) - PI) < 0.0000001) Then
      '取得距离最远的两个点。
      maxdi = MaxDouble(GetDistance(pt1, pt2), GetDistance(pt1, pt3), GetDistance(pt1, pt4), _
                        GetDistance(pt2, pt3), GetDistance(pt2, pt4), GetDistance(pt3, pt4))
      If GetDistance(pt1, pt2) = maxdi Then lpt1 = pt1: lpt2 = pt2
      If GetDistance(pt1, pt3) = maxdi Then lpt1 = pt1: lpt2 = pt3
      If GetDistance(pt1, pt4) = maxdi Then lpt1 = pt1: lpt2 = pt4
      If GetDistance(pt2, pt3) = maxdi Then lpt1 = pt2: lpt2 = pt3
      If GetDistance(pt2, pt4) = maxdi Then lpt1 = pt2: lpt2 = pt4
      If GetDistance(pt3, pt4) = maxdi Then lpt1 = pt3: lpt2 = pt4
      '画直线
      Select Case line1.ObjectName
         Case "AcDbLine"
           line1.StartPoint = lpt1
           line1.EndPoint = lpt2
           line2.Delete
           ThisDrawing.Utility.Prompt "线段已连接为直线."
           unite2Line = True
         Case "AcDbPolyline"
           Dim newPline As AcadLWPolyline
           Set newPline = AddLWPlineSeg(lpt1, lpt2, line1.ConstantWidth)
           newPline.Layer = line1.Layer
           newPline.color = line1.color
           newPline.Linetype = line1.Linetype
           line1.Delete
           line2.Delete
           Set line1 = newPline
           ThisDrawing.Utility.Prompt "线段已连接为多段线."
           unite2Line = True
      End Select
  Else: ThisDrawing.Utility.Prompt "两线不在同一直线上,退出命令."
  End If
End Function
'以下是上述代码调用的函数
'创建轻量多段线(只有两个顶点的直线多段线)
Public Function AddLWPlineSeg(ByVal ptSt As Variant, ByVal ptEn As Variant, Optional ByVal width As Double = 0) As AcadLWPolyline
    Dim objPline As AcadLWPolyline
    Dim ptArr(0 To 3) As Double
    ptArr(0) = ptSt(0)
    ptArr(1) = ptSt(1)
    ptArr(2) = ptEn(0)
    ptArr(3) = ptEn(1)
    Set objPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(ptArr)
    objPline.ConstantWidth = width
    objPline.Update
    Set AddLWPlineSeg = objPline
End Function
Public Function getLinePoint(ent As AcadEntity, ByRef Point1 As Variant, ByRef Point2 As Variant)
     '本函数得到线的端点,其中point1为Y坐标较小的点
    Dim p1(2) As Double
    Dim p2(2) As Double
    Dim k As Integer
        Select Case ent.ObjectName
            Case "AcDbLine"
                Point1 = ent.StartPoint
                Point2 = ent.EndPoint
                If ThisDrawing.Utility.AngleFromXAxis(Point1, Point2) >= PI Then
                    Point1 = ent.EndPoint
                    Point2 = ent.StartPoint
                End If
            Case "AcDbPolyline"
                Dim entCo As Variant
                entCo = ent.Coordinates
                k = UBound(entCo)
                If k >= 3 Then
                    p1(0) = entCo(0): p1(1) = entCo(1)
                    p2(0) = entCo(k - 1): p2(1) = entCo(k)
                    If ThisDrawing.Utility.AngleFromXAxis(p1, p2) >= PI Then
                        p2(0) = entCo(0): p2(1) = entCo(1)
                        p1(0) = entCo(k - 1): p1(1) = entCo(k)
                    End If
                    Point1 = p1: Point2 = p2
                End If
        End Select
End Function
Public Function PI() As Double
  PI = Atn(1) * 4
End Function
Public Sub GetEntityEx(ent As Object, pickedPoint, Optional Prompt)
  '选择实体,直到用户取消操作
StartLoop:
    ThisDrawing.Utility.GetEntity ent, pt, Prompt
    If Err Then
        If ThisDrawing.GetVariable("errno") = 7 Then
            Err.Clear
            GoTo StartLoop
        Else
            Err.Raise vbObjectError + 5, , "用户取消操作"
        End If
    End If
End Sub
Public Sub gwGetEntity(ent As Object, pickedPoint, Prompt As String, ParamArray gType())
 '选择某一类型的实体,如果选择错误则继续,按ESC退出
 'gtype是实体名称,不区分大小写,可以用通配符号,如"AcDbBlockReference","acdb*text"等
 Dim i As Integer
 Dim pd As Boolean
 pd = False
 Do
  GetEntityEx ent, pickedPoint, Prompt
  If ent Is Nothing Then
    Exit Do
  ElseIf UBound(gType) - LBound(gType) + 1 = 0 Then
    Exit Do
  Else
    For i = LBound(gType) To UBound(gType)
      If UCase(ent.ObjectName) Like UCase(gType(i)) Then
        Exit Do
      Else
        pd = True
      End If
    Next i
    If pd Then ThisDrawing.Utility.Prompt "选择的实体不符合要求."
  End If
 Loop
End Sub
'计算两点之间距离
Public Function GetDistance(sp As Variant, ep As Variant) As Double
    Dim x As Double
    Dim y As Double
    Dim z As Double
    x = sp(0) - ep(0)
    y = sp(1) - ep(1)
    z = sp(2) - ep(2)
    GetDistance = Sqr((x ^ 2) + (y ^ 2) + (z ^ 2))
End Function
'返回两个Double类型变量的最大值
Public Function MaxDouble(ByVal a As Double, ParamArray b()) As Double
  MaxDouble = a
  Dim i As Integer
  For i = LBound(b) To UBound(b)
    If b(i) > MaxDouble Then MaxDouble = b(i)
  Next i
End Function
Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
  '返回一个空白选择集
    Dim ss As AcadSelectionSet
    Set ss = ThisDrawing.SelectionSets(ssName)
    If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
    ss.Clear
    Set CreateSelectionSet = ss
End Function
Public Sub BuildFilter(typeArray, dataArray, ParamArray gCodes())
    '用数组方式填充一对变量以用作为选择集过滤器使用
    Dim fType() As Integer, fData()
    Dim index As Long, i As Long
    index = LBound(gCodes) - 1
    For i = LBound(gCodes) To UBound(gCodes) Step 2
        index = index + 1
        ReDim Preserve fType(0 To index)
        ReDim Preserve fData(0 To index)
        fType(index) = CInt(gCodes(i))
        fData(index) = gCodes(i + 1)
    Next
    typeArray = fType: dataArray = fData
End Sub
 楼主| 发表于 2010-8-11 21:56:00 | 显示全部楼层
希望有高手解答,这是合并(连接)一条直线上的两条线的程序。
  1. //subtlation
复制代码
  1. uniteSS为框选。uniteline为一根一根选择(只能选择两根)。对多段线和直线都有效。
复制代码
 楼主| 发表于 2010-8-11 22:29:00 | 显示全部楼层
希望大虾们多多帮助,框选一直有错误:线段已连接为直线.执行错误  CAD2004版本的
发表于 2010-8-12 10:12:00 | 显示全部楼层
楼主犯了一个很常见的错误:在每次程序运行前应判断目标选择集(即本程序代码中的uniteSS)是否已存在,若是的话应先删除该选择集。否则可能导致程序出现意外。
以下为修改后的部分代码,供参考:
Sub uniteSS()
  Dim ss As AcadSelectionSets
  If Not IsNull(ss.Item("uniteSS")) Then
     ssetObj.Delete
  End If
  Dim fType, fData
 楼主| 发表于 2010-8-12 19:58:00 | 显示全部楼层
谢谢2楼,已经解决
GMT+8, 2025-6-2 03:54 , Processed in 0.187188 second(s), 24 queries , Gzip On.
