楼主: Gu_xl
[【Gu_xl】] 【Gu_xl】基于方位角计算的拓扑多边形自动构建快速算法
发表于 2017-12-30 14:28:32 | 显示全部楼层
chshsl 发表于 2017-8-9 11:01
经过2天的研究G大侠的代码及网盘函数库,复原了,所缺的几个函数,见大家都希望补全,现贴上。希望G大侠不 ...
error: no function definition: GXL-SEL-SS->LIST; 出错后重置,请问这个又是什么
发表于 2018-1-10 10:55:11 | 显示全部楼层
;;;根据线段图元表构建二维坐标表'((首端点 末端点)  ...)
(defun gxl-ent->Coordinates1 (enLst)
  (mapcar '(lambda (x)
     (list (list (car (setq a (vlax-curve-getStartPoint x))) (cadr a))
   (list (car (setq a (vlax-curve-getendPoint x))) (cadr a))
     ) ;_ list
   ) ;_ lambda
  enlst
  ) ;_ mapcar
) ;_ defun
;;;gxl-Sel-EntNextAll en 返回 en 之后的所有物体选择集,无则返回 nil
(defun gxl-Sel-EntNextAll (ent / ss ent1)
(setq ss (ssadd))
(while (setq ent1 (entnext ent))
(ssadd ent1 ss)
(setq ent ent1)
(if (= 0 (sslength ss))
nil
ss
;;;选择集转为图元列表
(defun gxl-Sel-SS->List (ss / cs_i out)
(if (= (type ss) 'PICKSET)
(setq cs_i 0.0
out '()
(repeat (sslength ss)
(setq out (cons (ssname ss cs_i) out))
(setq cs_i (1+ cs_i))
(setq out (reverse out))
;;图元列表转为选择集
(defun gxl-Sel-List->SS (Lst / en ss)
(setq ss (ssadd)
kk 0)
(foreach en Lst
(ssadd en ss)
(setq kk (1+ kk))
ss
发表于 2018-1-10 11:01:27 | 显示全部楼层
;;;(gxl-dxf ent i )取出图元索引i对应的值
(defun gxl-dxf (ent i)
(if (= (type ent) 'ename)
(setq ent (entget ent))
(cdr (assoc i ent))
;;;(gxl-CH_Ent ent i pt) 用新值pt更新图元ent索引i对应的值
(defun gxl-CH_Ent (ent i pt / en)
(if (assoc i (setq en (entget ent)))
(setq en (subst (cons i pt) (assoc i en) en))
(setq en (append en (list (cons i pt))))
(entmod en)
;;删除表中第N个元素
(defun gxl-removeNth (index lst / c rtn lst1)
  (if (>= index  (length lst)) ;_ index 越界
    lst
  (if (< index (/ (length lst) 2)) ;_ index位于前半截
  (setq c -1 lst1 lst)
  (vl-some '(lambda (x) (if (equal index (setq c (1+ c))) t (progn (setq rtn (cons x rtn) lst1 (cdr lst1)) nil))) lst)
  (append (reverse rtn) (cdr lst1))
    (progn ;_ index位于后半截
      (setq index (- (length lst) index 1) lst (reverse lst))
  (reverse (append (reverse rtn) (cdr lst1)))
(defun gxl-massoc( d li /  a  ls )
        (setq ls '())
        (while (assoc d li)
                        (setq  a (assoc d li))
                        (setq ls (cons (list (cadr a) (caddr a)) ls))
                        (setq li (xdlsp_list_remove li  a))
        (reverse ls)
;输出50个空格
;(gxl-Str-Space 50) "                                                  "
;(gxl-Str-Space -1)
(defun gxl-Str-Space ( d  /  a )
    (setq a "")
        (if (>  d 0)
                (repeat d
                  (setq a (strcat a " " ))
        a
;删除表中重复项
(defun gxl-ListDumpAtom( l1 /  l2)
(while(setq l2(cons(car l1)l2) l1(vl-remove(car l1)(cdr l1))))
(reverse l2)
;; 曲线一点的切线方向的角度
;;示例(HH:PtFirstAngle (car (entsel)) (getpoint))
(defun gxl-GetCurveTangent (obj pt)
  (setq param (vlax-curve-getParamAtPoint obj pt))
  (angle pt (mapcar '+ pt (vlax-curve-getFirstDeriv obj param)))
;;常用变量
(setq
      pi2           (* pi 0.5)
      pi4           (* pi 0.25)
      2pi           (* pi 2.)
      3pi2           (* 1.5 pi)
      3pi4   (+ pi2 pi4)
      5pi4   (+ pi pi4)
      7pi4 (+ 3pi2 pi4)
      #ZJWS# 2
      *jd* 0.00001
这次应该是齐了,因为我这里运行已经没问题了。
发表于 2018-3-6 12:29:02 | 显示全部楼层
thanksgiving
发表于 2018-3-16 20:23:24 | 显示全部楼层
; 错误: no function definition: SETUNDOERR,提示这个,
发表于 2018-3-20 13:06:10 | 显示全部楼层
值得下載學習!
发表于 2018-4-8 17:28:41 | 显示全部楼层
太厉害了,换个镂空
发表于 2018-4-18 09:56:34 | 显示全部楼层
这个程序好复杂啊,新手只好先保留备学
发表于 2018-5-1 11:10:02 | 显示全部楼层
学习研究下拓扑。。
GMT+8, 2025-7-7 09:47 , Processed in 0.246163 second(s), 19 queries , Gzip On.
