查看: 2161|回复: 4
[讨论][求助]vba利用鼠标获取text里面的数值。
发表于 2010-7-9 09:48:00 | 显示全部楼层 |阅读模式
各位达人,在VBA中如何利用鼠标获取text里面的数值?
发表于 2010-7-9 19:31:00 | 显示全部楼层
没人 回答 呀
发表于 2010-7-9 21:27:00 | 显示全部楼层
问题描述的太简单,没看懂
 楼主| 发表于 2010-7-12 10:24:00 | 显示全部楼层
终于搞出来了
贡献一下:
Public Function selectTextNum() As Double
    On Error Resume Next
    Dim ssetobj As AcadSelectionSet
    Dim strText As String, dblText As Double
    Dim blnHaveFoundText As Boolean, intCount As Integer
    ThisDrawing.SelectionSets("getTextNum").Delete
    Set ssetobj = ThisDrawing.SelectionSets.Add("getTextNum")
    ThisDrawing.Utility.Prompt "请选择<Text>格式的实体!"
    Dim pickedObjs As AcadEntity
    '循环每个被选择的实体
    blnHaveFoundText = False: intCount = 0
    Do
        ssetobj.SelectOnScreen
        If checkkey(escape) = True Then GoTo Finish:
        If Err Then Err.Clear
        If ssetobj.count = 0 Then
            If vbNo = MsgBox("没有选择实体,是否重新点选?", vbYesNo) Then selectTextNum = -1: Exit Function 'GoTo Finish '如果没有选择物体,结束程序
        Else
            For Each pickedObjs In ssetobj
        '        If TypeOf pickedObjs Is AcadPolyline Or TypeOf pickedObjs Is Acad3DPolyline Then
        '        Debug.Print pickedObjs.ObjectName
        '        If pickedObjs.ObjectName = "AcDbMText" Then
        '            pickedObjs.Highlight (True) ' = acRed         '可将所有被选择实体将变为红色
        '            strText = pickedObjs.textString
        '            dblText = pickedObjs.Text
        '            selectTextNum = CDbl(strText)    '得到每个实体对象的文本内容
        '            pickedObjs.Highlight (False) ' = acRed         '可将所有被选择实体将变为红色
        '        End If
                If pickedObjs.ObjectName = "AcDbText" Then
                    ThisDrawing.Utility.Prompt "成功选取数值" & selectTextNum & ";" & vbCrLf
                    blnHaveFoundText = True
                End If
            Next
            intCount = intCount + 1
            If False = blnHaveFoundText Then
                If intCount < 3 Then
                    If vbNo = MsgBox("没有找到<Text>格式的实体,是否重新点选?", vbYesNo + vbQuestion) Then selectTextNum = -1: Exit Function
                Else
                    MsgBox "没有找到<Text>格式的实体,尝试超过3次,请手动输入!", vbInformation + vbCritical
                    selectTextNum = -1
                    Exit Function
                End If
            End If
        End If
    Loop While (False = blnHaveFoundText And intCount < 3)
    ssetobj.Clear:  ssetobj.Delete
    Exit Function
Finish:
  ssetobj.Delete
  selectTextNum = -1
End Function
发表于 2010-7-29 10:34:00 | 显示全部楼层
checkkey(escape)?
GMT+8, 2025-6-2 06:17 , Processed in 0.174522 second(s), 23 queries , Gzip On.
