帖子
查看: 3548|回复: 6
[讨论] [求助]跪求CAD两点连线程序
发表于 2010-7-2 22:14:00 | 显示全部楼层 |阅读模式
谁能帮我编一个单点号与双点号相连的程序,画一条直线把1点号与2点号相连,线断开,画一条直线把3点号与4点号相连,然后一直这样连线,如附件图示一.附件图示二是依点号用多段线连接然后闭合,
附件我已上传,附近我多上传了一个下载其中一个就可以了,
本人先感谢各位大哥,大姐们!
点号文本格式如下,格式为DAT格式.文本格式如下是,点号,,Y,X,Z
1,,95627.4450,31043.6450,28.7820
2,,95626.5460,31040.4170,29.0580
3,,95626.8920,31041.6020,28.9930
4,,95631.0180,31040.6380,29.2070
5,,95626.9330,31042.2100,28.9930
6,,95622.0840,31038.8780,29.3120
7,,95623.6240,31039.9740,29.2010
8,,95617.5520,31041.0470,29.4400
9,,95627.5010,31043.7780,28.8500
 楼主| 发表于 2010-7-8 00:07:00 | 显示全部楼层
[求助]
不会是没有人会吧,怎么久都没有消息
发表于 2010-7-8 08:45:00 | 显示全部楼层
看不懂你的附件哦,词不达意的
发表于 2010-7-8 09:52:00 | 显示全部楼层
(defun c:tttt ( / file fid p1 p2 )
   (if (and (setq file (getfiled "选择文件" "" "*" 8))
            (setq fid (open file "r"))
      (while
          (and (setq p1 (read-line fid))
               (setq p2 (read-line fid))
          (while (/= "," (substr p1 1 1)) (setq p1 (substr p1 2)))
          (while (/= "," (substr p2 1 1)) (setq p2 (substr p2 2)))
          (command "line" (substr p1 3) (substr p2 3) "")
    (if fid (close fid))
 楼主| 发表于 2010-7-8 19:07:00 | 显示全部楼层
程序不可以用
发表于 2010-7-8 21:28:00 | 显示全部楼层
(command "line" (substr p1 3) (substr p2 3) "")中(substr p2 3)的右括号改为西文右括号即可
 楼主| 发表于 2010-7-8 21:48:00 | 显示全部楼层
谢谢,完全可以用非常感谢你,
GMT+8, 2025-7-4 21:32 , Processed in 0.183633 second(s), 27 queries , Gzip On.
