查看: 2457|回复: 3
求救关于CAD二次开发的问题
发表于 2010-6-20 15:14:00 | 显示全部楼层 |阅读模式
在一篇论文中看到一个关于坐标系转换的程序,但是该程序在运行时,却提示“参数不可选”!是怎么回事啊?提示出错的就是下面加粗的那一行
Dim origin(0 To 2) As Double
Dim xAxisPnt(0 To 2) As Double
Dim yAxisPnt(0 To 2) As Double
Dim org As Variant
Dim xAxisp As Variant
Dim yAXISP As Variant
If ThisDrawing.GetVariable("UCSNAME") = "" Then
With ThisDrawing '当前坐标系未保存则保存之
Set CUITUCS = .UserCoordinateSystems.Add(.GetVariable("UCSORG"), .Utility.TranslateCoordinates(.GetVariable("UCSXDIR"), acUCS, acWorld, 0).Utility.TranslateCoordinates(.GetVariable("UCSYDIR"), acUCS, acWorld, 0), "clucs")
End With
Else
Set CUITUCS = ThisDrawing.ActiveUCS '保存当前坐标系
End If
'创建误差预计坐标系
MsgBox "创建误差预计坐标系"""
org = ThisDrawing.Utility.GetPoint(, "输入原点")
origin(0) = org(0): origin(1) = org(1): origin(2) = org(2)
xAxisp = ThisDrawing.Utility.GetPoint(, "x正方向上一点")
xAxisPnt(0) = xAxisp(0): xAxisPnt(1) = xAxisp(1): xAxisPnt(2) = xAxisp(2)
yAXISP = ThisDrawing.Utility.GetPoint(, "Y正方向上一点")
yAxisPnt(0) = yAXISP(0): yAxisPnt(1) = yAXISP(1): yAxisPnt(2) = yAXISP(2)
'创建预计坐标系为当前坐标系
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPnt, yAxisPnt, "yj-UCS")
ThisDrawing.ActiveUCS = ucsObj '将新建坐标系置为当前
End Sub
 楼主| 发表于 2010-6-21 11:54:00 | 显示全部楼层
怎么没人回答啊?
发表于 2011-12-18 23:48:08 | 显示全部楼层
http://www.mjtd.com/object/acad2004/ex_ucss.htm
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=76991
发表于 2012-6-16 17:07:01 | 显示全部楼层
学习,看看而已
GMT+8, 2025-5-1 02:48 , Processed in 0.148091 second(s), 25 queries , Gzip On.
