查看: 1825|回复: 6
[基础] 程序运行第一次良好,二次以后出现“参数太多”,或是结果不对
发表于 2010-6-11 09:01:00 | 显示全部楼层 |阅读模式
defun c:wc( / hh p1 p2 p3 p4 pa pb pc pd  w1 ww)
        (setvar "cmdecho" 0 )
        (setvar "blipmode" 0 )
 (setq pa (getpoint "请输入第一点"))
 (setq ww (getreal "\n请输入门洞宽度"))
 (setq hh (getreal "\n请输入门洞高度"))
 (setq w1 (getreal "\n请输入周边框宽度"))
 (setq pb (polar pa 0 ww))
 (setq pc (polar pb (/ pi 2) hh))
 (setq pd (polar pa (/ pi 2) hh))        ;矩形四角点pa,pb,pc,pd
 (setq p1 (polar pa 0 w1))
 (setq p2 (polar pa 0 (- ww w1)))
 (setq p3 (polar p2 (/ pi 2) (- hh w1)))
 (setq p4 (polar p1 (/ pi 2) (- hh w1))) ;内四角点p1,p2,p3,p4
 (command "pline" pa pd pc pb p2 p3 p4 p1 "c")
 (prin1)
(prompt ***********<< uad wc >>***********)
 (prin1)
问题:第二次再运行 出来的结果是,只画出pa pd pc pb 就结束了,
file://C:\Documents and Settings\SJ\桌面\未命名.jpg( 如何让截图显示,本人不会发贴子 ,技术问题太弱)
 楼主| 发表于 2010-6-11 09:01:00 | 显示全部楼层
图出来了??呵呵
明经网友  发表于 2010-6-11 09:25:00
我试了一下,三次运行均正常。 AutoCAD 2010
使用道具
 楼主| 发表于 2010-6-11 09:28:00 | 显示全部楼层
我再试试,我用的2004,
发表于 2010-6-11 17:57:00 | 显示全部楼层
没有问题
  1. (defun c:wc (/ hh p1 p2 p3 p4 pa pb pc pd w1 ww)
  2.   (setvar "cmdecho" 0)
  3.   (setvar "blipmode" 0)
  4.   (setq pa (getpoint "请输入第一点"))
  5.   (setq ww (getreal "\n请输入门洞宽度"))
  6.   (setq hh (getreal "\n请输入门洞高度"))
  7.   (setq w1 (getreal "\n请输入周边框宽度"))
  8.   (setq pb (polar pa 0 ww))
  9.   (setq pc (polar pb (/ pi 2) hh))
  10.   (setq pd (polar pa (/ pi 2) hh)) ;矩形四角点pa,pb,pc,pd
  11.   (setq p1 (polar pa 0 w1))
  12.   (setq p2 (polar pa 0 (- ww w1)))
  13.   (setq p3 (polar p2 (/ pi 2) (- hh w1)))
  14.   (setq p4 (polar p1 (/ pi 2) (- hh w1))) ;内四角点p1,p2,p3,p4
  15.   (command "pline" pa pd pc pb p2 p3 p4 p1 "c")
  16.   (princ)
  17. )
  18. (prompt "绘制门洞 wc")
发表于 2010-6-12 08:26:00 | 显示全部楼层
图出来了??呵呵
发表于 2010-6-12 08:52:00 | 显示全部楼层
 (command "_.pline" "non" pa "non" pd "non" pc "non" pb "non"  p2 "non" p3 "non" p4 "non" p1 "c")
GMT+8, 2025-7-30 01:10 , Processed in 0.178535 second(s), 25 queries , Gzip On.
