查看: 3299|回复: 4
[图元] 块属性是否可以设置为多行?
发表于 2010-6-8 10:31:00 | 显示全部楼层 |阅读模式
块属性是否可以设置为多行?   我想做个块,块的某个属性我想让它像多行文字一样显示为多行,是否可以实现?
发表于 2010-6-8 19:23:00 | 显示全部楼层
  1.         [CommandMethod("tt")]
  2.         public static void Test()
  3.         {
  4.             var db = HostApplicationServices.WorkingDatabase;
  5.             var doc = Application.DocumentManager.GetDocument(db);
  6.             using (var tr = db.TransactionManager.StartTransaction())
  7.             {
  8.                 var bt = db.BlockTableId.GetObject(OpenMode.ForWrite) as BlockTable;
  9.                 //创建一个无名块定义
  10.                 var blkdef = new BlockTableRecord();
  11.                 blkdef.Name = "*U";
  12.                 bt.Add(blkdef);
  13.                 tr.AddNewlyCreatedDBObject(blkdef, true);
  14.                 //向块定义添加实体
  15.                 Line line = new Line(Point3d.Origin, new Point3d(10, 0, 0));
  16.                 blkdef.AppendEntity(line);
  17.                 tr.AddNewlyCreatedDBObject(line, true);
  18.                 //向块定义添加多行属性
  19.                 AttributeDefinition attdef =
  20.                     new AttributeDefinition
  21.                     {
  22.                         Prompt = "Input A1:",
  23.                         Tag = "A1",
  24.                         Height = 5,
  25.                         IsMTextAttributeDefinition = true,
  26.                         Position = Point3d.Origin,
  27.                     };
  28.                 attdef.SetDatabaseDefaults();
  29.
  30.                 //在当前空间创建块引用
  31.                 var btr = db.CurrentSpaceId.GetObject(OpenMode.ForWrite) as BlockTableRecord;
  32.                 var blkref = new BlockReference(Point3d.Origin, blkdef.ObjectId);
  33.                 btr.AppendEntity(blkref);
  34.                 tr.AddNewlyCreatedDBObject(blkref, true);
  35.                 //在块引用中添加属性
  36.                 AttributeReference attref = new AttributeReference();
  37.                 attref.SetAttributeFromBlock(attdef, blkref.BlockTransform);
  38.                 attref.SetDatabaseDefaults();
  39.                 blkref.AttributeCollection.AppendAttribute(attref);
  40.                 tr.AddNewlyCreatedDBObject(attref, true);
  41.                 //更改属性的多行文字内容
  42.                 MText mt = attref.MTextAttribute;
  43.                 mt.Contents = @"123\p456";
  44.                 attref.MTextAttribute = mt;
  45.                 attref.UpdateMTextAttribute();
  46.                 tr.Commit();
  47.
  48.             }
  49.         }
发表于 2010-6-8 20:59:00 | 显示全部楼层
123
发表于 2010-6-8 21:27:00 | 显示全部楼层
学习了,原来块属性也可以用多行文本
发表于 2012-4-24 15:40:40 | 显示全部楼层
完全外行,请教一下怎样编译成可执行的文件?多谢了
GMT+8, 2025-5-3 05:19 , Processed in 0.140443 second(s), 24 queries , Gzip On.
