查看: 1826|回复: 2
[基础] [求助]dck中把点取的坐标赋给textt中?
发表于 2010-6-7 11:12:00 | 显示全部楼层 |阅读模式
大家好 我做了下面的界面
现在我点取“点击坐标”后怎么不能把点取的坐标值赋给X 和 Y中呢?但是我取得的变量还是有的啊
下面是我的程序
 (while (>= dow 2)
   (if(not(new_dialog "fgw" dcl_dtszh)) (exit))
   (if (/= tfm "") (set_tile "tfm" tfm))
   (if (= blc 0.5) (set_tile "bl_1" "1"))
   (if (= blc 1.0) (set_tile "bl_2" "1"))
   (if (= blc 2.0) (set_tile "bl_3" "1"))
   (if (= blc 5.0) (set_tile "bl_4" "1"))
   (action_tile "gpoint" "(done_dialog 2)")
   (action_tile "accept" "(fgw_ok) (done_dialog 1)")
   (action_tile "cancel" "(progn (done_dialog) (setq bz 0))")
   (setq dow (start_dialog))
   (if (= dow 2)
      (setq pt (getpoint "/n请选择图幅的左下角坐:"))
      (setq x1_pt (cadr pt))
      (setq y1_pt (car pt))
      (set_tile "x" (rtos x1_pt))
      (set_tile "y" (rtos y1_pt)) ;这两句是应该把坐标赋给上面的XY中的 为什么没有变化呢
 楼主| 发表于 2010-6-13 09:15:00 | 显示全部楼层
 (while (>= dow 2)
   (if (= dow 2)
这样就可以了 呵呵
GMT+8, 2025-7-30 00:45 , Processed in 0.183609 second(s), 25 queries , Gzip On.
