楼主: chenjian2159
[求助]大家帮忙看下这个功能能否实现
发表于 2011-7-13 15:26:21 | 显示全部楼层
凑足5个回复再说。
发表于 2011-7-13 15:48:58 | 显示全部楼层
以下vba代码可以完成相应功能。最后显示所有图层的实体。没有对话框。
  1. Sub LayerWalk()
  2. Dim objLayer As AcadLayer, objLayer2 As AcadLayer, str1 As String
  3. On Error GoTo ErrHand
  4. For Each objLayer In ThisDrawing.Layers
  5.     ThisDrawing.Utility.Prompt "当前显示图层为:" & objLayer.name & vbCrLf
  6.     ThisDrawing.ActiveLayer = objLayer
  7.     objLayer.LayerOn = True
  8.     For Each objLayer2 In ThisDrawing.Layers
  9.         If objLayer2.name <> objLayer.name Then
  10.             objLayer2.LayerOn = False
  11.         End If
  12.     Next objLayer2
  13.     str1 = ThisDrawing.Utility.GetString(0, "回车显示下一图层")
  14. Next objLayer
  15. ErrHand:
  16. For Each objLayer In ThisDrawing.Layers
  17.     objLayer.LayerOn = True
  18. Next objLayer
  19. End Sub
发表于 2011-7-16 10:01:35 | 显示全部楼层
;逐层查看
(defun C:VL(/ nlay)
   (cond ((= lla nil)(setq lla (list))
          (setq alla (tblnext "LAYER" T))
          (while  alla
                      (setq lla1(cdr (assoc '2 alla)))
                     (setq lla (cons lla1 lla))
                     (setq alla (tblnext "LAYER"))
          (setq lla (reverse lla))
        (T nil)
(setvar "cmdecho" 0)
   (if (= ilay nil)
       (setq ilay 0)
   (if (= ilay (length lla))
         (setq ilay 0)
   (command "_LAYER" "_S" (nth ilay lla) "_off" "*" "" "_on" "raster" "")
   (setq nlay (strcat "\n当前显示图层是; " (nth ilay lla) " 按确认跳转下一层!"))
   (princ nlay)
   (setq ilay (1+ ilay))
   (setvar "cmdecho" 1)
GMT+8, 2025-5-2 22:06 , Processed in 0.143839 second(s), 16 queries , Gzip On.
