查看: 1494|回复: 0
[求助]圆弧怎么填充?第一次填充不了,第二次就行了
发表于 2010-5-25 18:51:00 | 显示全部楼层 |阅读模式
就是一个三心拱,那拱部分怎么搞,程序第一次运行时就会出问题,第二次就填充上了,不知道怎么改了,哪位大侠帮帮忙?
     ;(command "pline" kkkk cced "")              ;连接左边两个大圆弧的端点
     ;(setq tuyuan61 (entlast))
     (command "pline" ccce ccec "")              ;连接左边两个小圆弧的端点
     ;(setq tuyuan62 (entlast))
     ;(command "pline" ccef pppp "")              ;连接右边两个大圆弧的端点
     ;(setq tuyuan63 (entlast))
     ;(command "pline" cceg qqqq "")              ;连接右边两个小圆弧的端点
     ;(setq tuyuan64 (entlast))
     (command "hatch" "AR-SAND" "1" "0"  "cp" ccdf2 ccea cceb ccce ccdf  ""  "" )                ;设置墙和拱填充样式
     (command "pline" cceh ccei ccej ccek qqqq "c")
     (setq tuyuan52 (entlast))
     (setq tczb2 (list (car cceg) (- (cadr cceg) 20)))
     (command "bhatch" tczb2 "")                                                  ;填充右半部分
  (command "pline" ccdf2 ccea cceb ccce ccdf2  "c")
  (setq tuyuan51 (entlast))
  (setq tczb1 (list (+ (car ccec ) (/ d0 2)) (- (cadr ccec) (/ h3 2))))         ;设置填充内的点
  (command "bhatch"  tczb1 "")                                                  ;填充左半部分墙
  (command "pline" cccc (polar cccc (/ pi 2)  (+ H 100)) "")
  (setq tuyuan53 (entlast))
  (setq tczb3 (list (- (car ccce) (/ d0 3)) (+ (cadr ccce) 10)))
  (command "bhatch" tczb3 "")                                                   ;填充拱左半部分
  (setq tczb31 (list (- (car cceg) (/ d0 2)) (+ (cadr ccce) 10)))
  (command "bhatch" tczb31 "")                                                  ;填充拱右半部分
  (command "erase" tuyuan51 tuyuan52 tuyuan53 tuyuan61 tuyuan62 tuyuan63 tuyuan64  "")
GMT+8, 2025-7-29 23:59 , Processed in 0.182976 second(s), 26 queries , Gzip On.
