网上下的程序,如何将该程序输出路径改为固定d:/BB.xls,先谢谢各位! (defun C:NB() (graphscr) (setq cmd (getvar "cmdecho")) (setvar "cmdecho" 0) ;输出文件选择 (setq dwg_name (getvar "dwgname""d:/")) (setq dwg_name_len (strlen dwg_name)) (setq lay_name_len (- dwg_name_len 4)) (setq dwg_name (substr dwg_name 1 lay_name_len)) (initget 1 "N S") (setq ch (strcase (getkword "\n新建文件/打开文件 [N/S]:"))) (cond ((= ch "N") (setq file_name (getfiled "指定输出的文件名称" dwg_name "xls" 1))) ((= ch "S") (setq file_name (getfiled "指定输出的文件名称" dwg_name "xls" 0))) ) (setq file_id (open file_name "a"))
;对象选择 (setq ent_list (ssget)) (setq ent_list_len (sslength ent_list)) (setq id 0) (repeat ent_list_len (setq ent_data (entget (ssname ent_list id))) (setq id (1+ id)) (setq ent_data_lay (assoc 1 ent_data)) (setq ent_data_name (cdr ent_data_lay)) (setq ent_data_lay2 (assoc 0 ent_data)) (setq ent_data_mode (cdr ent_data_lay2)) (if (or (= ent_data_mode "TEXT") (= ent_data_mode "MTEXT")) (progn (princ ent_data_name file_id) (princ "\n" file_id) ) ) ) ;加入单文字名为序列 (princ "\n已完成文字输出") (close file_id) ;序列输出为文本文件 (setvar "cmdecho" cmd) ) |
