查看: 1943|回复: 0
[基础] [求助]能不能不让命令行一行一行地往上跳
发表于 2010-5-17 10:23:00 | 显示全部楼层 |阅读模式
  1. ;;;从网上下载程序改装如下,能不能不让命令行一行一行地往上跳 (vl-load-com)
复制代码
;;;喷头位置移到吊顶格栅中间(defun c:pt (/ err)  (defun algion                (msg                /      ss     lst    i                    vlalst boxlst x                cor1   cor2   findboxpt                    newboxpt en1                en     enlst  y                     y2                    lsta)    (princ msg)    (setvar "cmdecho" 0)    (setvar "OSMODE" 0)    (setq ss (ssget '((0 . "CIRCLE") (8 . "cxb_喷头"))))    (setq i 0)    (repeat (sslength ss)      (setq lst (cons (ssname ss i) lst))      (setq i (1+ i))    )    (setq vlalst (mapcar 'vlax-ename->vla-object lst))    (setq boxlst (mapcar '(lambda (x)    (cdr (assoc 10 (entget x)))  ) lst )    )    (mapcar '(lambda (x / dxf)       (setq dxf (entget x))       (if (assoc 60 dxf) (entmod (subst '(60 . 1) (assoc 60 dxf) dxf));用entdel好象会出问题 (entmod (append dxf '((60 . 1))))       )     )    lst    )    (setq newboxpt   (mapcar '(lambda (x)      (setq en1 (entlast))      (vla-zoomcenter(vlax-get-acad-object)(vlax-3d-point x)5000      );否则boundary速度很慢      (vl-cmdf "_.boundary" x "")      (setq en (entlast))      (vla-ZoomPrevious (vlax-get-acad-object))      (if (not (equal en1 en))(progn  (setq enlst (entget en))  (setq                lsta (vl-remove-if-not       '(lambda (y) (= (car y) 10))       enlst     )  )  (setq                cor1 (vl-remove 10 (car lsta))cor2 (vl-remove 10 (nth 2 lsta))  )  (entdel en)  (polar cor1 (angle cor1 cor2) (/ (DISTANCE cor1 cor2) 2.0)  ))      )    )   boxlst   )    )    (mapcar '(lambda (x / dxf)       (setq dxf (entget x))       (entmod (subst '(60 . 0) (assoc 60 dxf) dxf));用entdel还原不了?     )    lst    )    (mapcar '(lambda (x y y2)       (vla-move x (vlax-3d-point y) (vlax-3d-point y2))     )    vlalst    findboxpt    newboxpt    )  )
  (setq err (VL-CATCH-ALL-APPLY 'algion (list "\n选择喷头: ")));;;(vla-ZoomExtents (vlax-get-acad-object))  (setvar "cmdecho" 1)  (setvar "OSMODE" 4151)  (princ))
GMT+8, 2025-7-30 00:15 , Processed in 0.166705 second(s), 25 queries , Gzip On.
