查看: 1617|回复: 1
BOM号码标注,请各位帮忙调试一下。红色文字部分
发表于 2010-5-15 16:06:00 | 显示全部楼层 |阅读模式
(defun c:zbom(/ old_la old_os sc ra ddr pt1 pt2 pp)
  (setq old_la (getvar "clayer"))
  (setq old_os (getvar "osmode"))
  (prompt "\n 输入≦10000的编号!")
  (if (= num nil) (setq num 1))
  (setq num (getint (strcat "起始序号<"(itoa num) ">")))   ;;;;取得上次的编号敲回车或空格不起作用
  (if (= num nil) (setq num num));;;;;;;;;;;;;代码不起作用
  (cond ((> num 10000)
             (prompt "\n 编号超过最大范围 10000,重新输入!")
        ((< num 1)
              (prompt "\n 编号必须 ≧1 ,重新输入!")
  );;end cond
  (setq sc (getreal (strcat "请输入字高<" (rtos (* (getvar "dimtxt")(getvar "dimscale"))) ">")))
  (if (= sc nil) (setq sc (* (getvar "dimtxt")(getvar "dimscale"))))
  (setq ra ( * sc 2))
  (setq ddr 0.5)
  (setq pt1 (getpoint "\n第一点:"))
    (while (/= pt1 nil)
      (setq pt2 (getpoint pt1 "\n第二点:"))
      (setvar "osmode" 0)
      (setq pp (polar pt1 (angle pt1 pt2) (- (distance pt1 pt2) ra)))
      (command  "donut" 0 ddr pt1 "")
      (command "pline" pt1 pp "")
      (command "circle" pt2 ra)
      (command "text" "m" pt2 sc 0 num)
      (setq num (1+ num))
      (if (> num 10000)(progn (alert "\n 编号已达到最大范围!")(exit)))
      (setvar "osmode" old_os)
  (setvar "clayer" old_la)
 楼主| 发表于 2010-5-15 16:18:00 | 显示全部楼层
(defun c:zbom(/ old_la old_os num sc ra ddr pt1 pt2 pp)
  ;(cmdf)
(defun *error* (msg)
  (if (= num nil) (setq num1 1))
  (setq num (getint (strcat "起始序号<"(itoa num1) ">")))
  (if (= num nil) (setq num num1))
  (cond ((> num 9998)
        ((< num 1)
  );;end cond
  (setq ra ( * sc 2))
  (setq ddr 0.5)
 ; (if (= (tblsearch "layer" "汽泡球层") nil)(new_lay "汽泡球层"   241  "PHANTOM"))
  ;(setvar "clayer" "汽泡球层")
    (while (/= pt1 nil)
      (setvar "osmode" 0)
      (setq num (1+ num))
      (if (> num 9999)(progn (alert "\n 编号已达到最大范围!")(setq num 1)(exit)))
      (setq num1 num)
  ;(xhinfo)
对于大于9999和小于1 的数字处理还有问题,各位帮忙下
GMT+8, 2025-7-30 00:03 , Processed in 0.215068 second(s), 25 queries , Gzip On.
