查看: 1939|回复: 2
[求助]六角头螺栓的lisp程序调试
发表于 2010-5-13 16:53:00 | 显示全部楼层 |阅读模式
代码中没有俯视图和左视图
请问哪里出错了啊 找不到啊!请各位大侠帮帮忙找找,小弟不胜感激!
 楼主| 发表于 2010-5-13 17:01:00 | 显示全部楼层
好像没有上传文件啊我发一下
(defun c:ljls (/    e0  e1   xzj  d0 k    k1   p0   pt0  ang  l
        d    val  t=zfz    prpl p1   p2   p3   p4   p5  p6
        p7   p8  p1d  p2d  p3d p4d  p5d  p6d  p7d  p8d  p9
(defun f_gettc ()
  (setq os (getvar "osmode"))
  (setq sc (getvar "cmdecho"))
  (setq pre (getvar "luprec"))
  (setq clay (getvar "clayer"))
  (setvar "osmode" 0)
  (setvar "cmdecho" 0)
  (setvar "luprec" 1)
  (setq e0 (entlast))
  (setq p0 '(0 0))
  (setq pt0 (getpoin "输入基点<缺省(0,0)>:"))
  (if (=pt0 nil)
    (seetq pt0 (list 0 0))
  (setq ang (getangle pt0 "输入旋转角:"))
  (setq l (getdist "输入公称长度(L):"))
  (setq d (getdist "输入公称直径(D):"))
  (setq val (getdist "输入缩放比例<1.0>:"))
  (if (= val nil)
    (setq val 1.0)
  setq
  t_zfz
  (getint "选择视图(0-主视图\\1-俯视图\\2-左视图)<0>:")
(if (= t_zfz nil)
  (setq t_zfz 0)
(if (and (/= t_zfz 0) (/= t_zfz 1) (/= t_zfz 2))
  (progn (print "选择视图错误!退出程序!") (exit))
(f_gettc)
(if (= t_zfz 0)
    (setq d0 (/ d 2))
    (setq k  (* d 0.7)
   k1 (* k 0.7)
    (setq p1  (list 0 (- d0 1))
   p2  (list 0 d0)
   p3  (list 0 d)
   p4  (list 1 (- d0 1))
   p5  (list 1 d0)
   p6  (list (-k1) d0)
   p7  (list (-k) (* d0 1.5))
   p8  (list (-k1) d)
   p1d (list 0 (- 1 d0))
   p2d (list 0 (-d0))
   p3d (list 0 (-d))
   p4d (list l (- 1 d0))
   p5d (list l (-d0))
   p6d (list (-k1) (-d0))
   p7d (list (-k) (* d0 -1.5))
   p8d (list (-k1) (-d))
   p9  (list (-k) 0)
    (setq pr (list (- (+ k 5)) 0)
   pl (list (+ l 5) 0)
    (command "zoom" "w" pr pl)
    (command "layer" "m" "0" "c" 7 "0" "1" "continuous" "0" "lw" 0.36
      "0" "")
    (command "line" p8 p3 p3d p8d "" "line" p7 p7d "" "line" p6 p5 p5d
      p6d "")
    (command "arc" p6 p7 p8 "arc" p6d p7d p8d "arc" p6 p9 p6d)
    (command "layer" "m" "1" "c" 1 "1" "1" "continuous" "1" "lw" 0.18
      "1" "")
    (command "line" p1 p4 "" "line" p1d p4d "")
    (command "layer" "m" "6" "c" 3 "6" "1" "centerX2" "6" "lw" 0.18 "6"
    (command "line" pr pl "")
发表于 2010-5-13 22:27:00 | 显示全部楼层
  1. (defun c:ljls (/    e0  e1   xzj  d0 k    k1   p0   pt0  ang  l
  2.         d    val  t_zfz    prpl p1   p2   p3   p4   p5  p6
  3.         p7   p8  p1d  p2d  p3d p4d  p5d  p6d  p7d  p8d  p9
  4.        )
  5. (defun f_gettc ()
  6.   (setq os (getvar "osmode"))
  7.   (setq sc (getvar "cmdecho"))
  8.   (setq pre (getvar "luprec"))
  9.   (setq clay (getvar "clayer"))
  10.   (setvar "osmode" 0)
  11.   (setvar "cmdecho" 0)
  12.   (setvar "luprec" 1)
  13. )
  14. (setq e0 (entlast))
  15. (setq p0 '(0 0))
  16. (setq pt0 (getpoint "\n输入基点<缺省(0,0)>:"))
  17. (if (= pt0 nil) (setq pt0 (list 0 0)))
  18. (setq ang (getangle pt0 "\n输入旋转角 :"))
  19. (setq l (getdist "\n输入公称长度(L) :"))
  20. (setq d (getdist "\n输入公称直径(D) :"))
  21. (setq val (getdist "\n输入缩放比例<1.0> :"))
  22. (if (= val nil) (setq val 1.0))
  23. (setq t_zfz (getint "\n选择视图(0-主视图\\1-俯视图\\2-左视图)<0> :"))
  24. (if (= t_zfz nil) (setq t_zfz 0))
  25. (if (and (/= t_zfz 0) (/= t_zfz 1) (/= t_zfz 2))
  26.   (progn (print "\n选择视图错误!退出程序!") (exit))
  27. )
  28. (f_gettc)
  29. (if (= t_zfz 0) (progn
  30.   (setq d0 (/ d 2))
  31.   (setq k  (* d 0.7)
  32.         k1 (* k 0.7))
  33.   (setq p1  (list 0 (- d0 1))
  34.         p2  (list 0 d0)
  35.         p3  (list 0 d)
  36.         p4  (list l (- d0 1))
  37.         p5  (list l d0)
  38.         p6  (list (- k1) d0)
  39.         p7  (list (- k) (* d0 1.5))
  40.         p8  (list (- k1) d)
  41.         p1d (list 0 (- 1 d0))
  42.         p2d (list 0 (- d0))
  43.         p3d (list 0 (- d))
  44.         p4d (list l (- 1 d0))
  45.         p5d (list l (- d0))
  46.         p6d (list (- k1) (- d0))
  47.         p7d (list (- k) (* d0 -1.5))
  48.         p8d (list (- k1) (- d))
  49.         p9  (list (- k) 0))
  50.   (setq pr (list (- (+ k 5)) 0)
  51.         pl (list (+ l 5) 0))
  52.   (command "zoom" "w" pr pl)
  53.   (command "layer" "m" "0" "")
  54.   (command "line" p8 p3 p3d p8d "" "line" p7 p7d "" "line" p6 p5 p5d p6d "")
  55.   (command "arc" p6 p7 p8 "arc" p6d p7d p8d "arc" p6 p9 p6d)
  56.   (command "layer" "m" "1" "c" 1 "" "")
  57.   (command "line" p1 p4 "" "line" p1d p4d "")
  58.   (command "layer" "m" "6" "c" 3 "" "L" "center2" "" "")
  59.   (command "line" pr pl "")
  60. ))
  61. )
GMT+8, 2025-7-29 23:56 , Processed in 0.159018 second(s), 26 queries , Gzip On.
