查看: 1679|回复: 1
[求助]急!!关于获取pline线偏移后的坐标问题
发表于 2010-5-11 08:50:00 | 显示全部楼层 |阅读模式
'我想获取pline线偏移后的实体(pline)坐标;下面的代码怎么无法实现呢?
'请高手赐教,谢谢!!!!!!!
  Sub LinetoBOX2()
      Dim returnObj As AcadObject
      Dim sset As AcadSelectionSet
      Dim COOR As Variant
      Dim CoorL As Variant
      Dim CoorR As Variant
      Dim xtype1 As Variant
      Dim xdata1 As Variant
      Dim objPl As AcadPolyline
      Dim objPlL As AcadPolyline
      Dim objPlR As AcadPolyline
      Dim obj As AcadObject
      Dim basepnt As Variant
      Dim offsetObjL As Variant
      Dim offsetObjR As Variant
    On Error Resume Next
      If Not IsNull(ThisDrawing.SelectionSets.Item("this")) Then
        Set sset = ThisDrawing.SelectionSets.Item("this")
        sset.Delete
      End If
      Set sset = ThisDrawing.SelectionSets.Add("this")
     sset.SelectOnScreen
     If sset.Count = 0 Then Exit Sub
      Dim s As String
      Dim S2 As String
      Dim offsetval As Double
    For Each obj In sset
      MsgBox obj.ObjectName
      If obj.ObjectName = "AcDbPolyline" Then
                Set objPl = obj
                'If obj.ConstantWidth > 0 Then
               ' offsetval = obj.ConstantWidth
                    '向左偏移
                    offsetObjL(0) = objPl.Offset(1.0)
                    Set objPlL = offsetObjL(0)
                    CoorL = objPlL.Coordinates
                     For i = 0 To UBound(CoorL) 'Step 3
                       s = s + Format(CoorL(i), "0.000") + "," '+ Format(CoorL(i + 1), "0.000") + Format(CoorL(i + 2), "0.000") + vbCrLf
                     Next i
                     '向右偏移
                    offsetObjR(0) = objPl.Offset(-1.0)
                    Set objPlR = offsetObjR(0)
                     CoorR = objPlR.Coordinates
                      For i = 0 To UBound(CoorR) 'Step 3
                       S2 = S2 + Format(CoorR(i), "0.000") + "," '+ Format(CoorR(i + 1), "0.000") + Format(CoorR(i + 2), "0.000") + vbCrLf
                     Next i
                   MsgBox s + vbCrLf + "*************************************" + vbCrLf + S2
                   'ThisDrawing.SendCommand "huan" & vbCr
                   'ThisDrawing.SendCommand "(command " & """huan""" & " "")"
                End If
             End If
         Next
        sset.Clear
          MsgBox "数据处理完毕!", vbInformation
          sset.Delete
         Exit Sub
line:
        MsgBox Err.Description, vbCritical
  End Sub
 楼主| 发表于 2010-5-11 13:48:00 | 显示全部楼层
  已解决,谢谢各位
把    Dim objPl As AcadPolyline
改为
Dim objPl As AcadLWPolyline
      Dim objPlL As AcadLWPolyline
      Dim objPlR As AcadLWPolyline
即可
GMT+8, 2025-6-3 19:06 , Processed in 0.176715 second(s), 23 queries , Gzip On.
