查看: 1663|回复: 3
[求助]求源代码
发表于 2010-5-9 15:47:00 | 显示全部楼层 |阅读模式
        求VBA环境下编辑的要求查询坐标,方位角,距离和面积的源代码
发表于 2010-5-10 12:22:00 | 显示全部楼层
Point= ThisDrawing.Utility.GetPoint(, vbCrLf & "选择点")
ThisDrawing.Utility.Prompt "X坐标= " & Point(1) & "   Y坐标= " & Point(0) & "   H高程 =" & Point(2) & Chr(13) & vbCrLf
Point1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "选择第一点")
Point2= ThisDrawing.Utility.GetPoint(Point1, "选择第二点")
D = Sqr(Point2(1)-Point1(1)* Point2(1)-Point1(1) +Point2(0)-Point1(0) * Point2(0)-Point1(0))
FWJ=Fwjjs(Point1,Point2)
Public Function Fwjjs(PointA As Variant, PointB As Variant)  '方位角
    Dim dx As Double
    Dim dy As Double
    Dim TR As Double
    dx = PointB(1) - PointA(1)
    dy = PointB(0) - PointA(0)
    If dx = 0 Then
        TR = Sgn(dy) * PI / 2
    Else
        TR = Atn(dy / dx)
        If dx < 0 Then TR = TR + PI
    End If
    If dx >= 0 And dy < 0 Then TR = TR + 2 * PI
    Fwjjs = TR
End Function
Dim objDest As AcadEntity
Dim ptBase As Variant
ThisDrawing.Utility.GetEntity objDest, ptBase, " 选择对象>>"
S = objDest.area
 楼主| 发表于 2010-5-12 11:12:00 | 显示全部楼层
谢谢啊
 楼主| 发表于 2010-5-14 21:04:00 | 显示全部楼层
    好像只有求坐标的没出问题,其他的都有问题呀。。
GMT+8, 2025-6-3 19:12 , Processed in 0.178096 second(s), 24 queries , Gzip On.
