查看: 1819|回复: 0
调试Autodesk官方例题出现的问题
发表于 2010-5-7 09:36:00 | 显示全部楼层 |阅读模式
        [CommandMethod("createLayer")]
        public ObjectId CreateLayer()   //-----------------------------------1-------------------------------
            ObjectId layerId=new ObjectId(); //它返回函数的值
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            Transaction trans = db.TransactionManager.StartTransaction();
            //首先取得层表……
            LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForWrite);
            //检查EmployeeLayer层是否存在……
            if (lt.Has("EmployeeLayer"))
                layerId = lt["EmployeeLayer"];
            else
                //如果EmployeeLayer层不存在,就创建它
                LayerTableRecord ltr = new LayerTableRecord();
                ltr.Name = "EmployeeLayer"; //设置层的名字
                ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 2);
                layerId = lt.Add(ltr);
                trans.AddNewlyCreatedDBObject(ltr, true);
            trans.Commit();
            trans.Dispose();
            return layerId; //-----------------------------------2-------------------------------
调试时报错,但将程序返回类型改为void:-----1--------处改为public void CreateLayer()   ,-------2------处去掉,则可正常建立层,这是为什么?
另外,要将建立的层设为当前层,我该怎么做?
GMT+8, 2025-5-25 06:36 , Processed in 0.152088 second(s), 23 queries , Gzip On.
