楼主: xransnow
[基础] [求助]使用lisp或者vlisp是否可行?
发表于 2010-5-6 21:10:00 | 显示全部楼层
(setq sa "")
(foreach x (list "aaa" "bbb" "ccc" "ddd") (setq sa (strcat sa x "/")))
(setq sa (substr sa 1 (1- (strlen sa))))
发表于 2010-5-8 10:32:00 | 显示全部楼层
可以实现吧,不过丝路很难
 楼主| 发表于 2010-5-10 13:15:00 | 显示全部楼层
我怎么得不到“8820.0”,请高手指导下
发表于 2010-5-10 14:37:00 | 显示全部楼层
先(setvar "DIMZIN" 0)再转换
 楼主| 发表于 2010-5-15 09:24:00 | 显示全部楼层
看了各位的回复,收获很大,谢谢各位
继续请教
(setq startnum (getint "\n请输入起始序号:"))
在用户直接回车的时候,会提示“错误: 参数类型错误: numberp: nil”
怎么可以给startnum赋值一个默认值?而不因为错误中断程序?
发表于 2010-5-15 09:49:00 | 显示全部楼层
其下加
(if (not startnum )
  (setq startnum DefVal)
or
类似 uint 的函数
    ;* UINT User interface integer function
    ;* BIT (0 for none) and KWD key word ("" for none) are same as for INITGET.
    ;* MSG is the prompt string, to which a default integer is added as <DEF> (nil
    ;* for none), and a : is added.
    (defun uint (bit kwd msg def / inp)
      (if def                                                 ;test for a default
        (setq msg (strcat "\n >> " msg " < " (itoa def) " >: ")      ;string'em with default
             bit (* 2 (fix (/ bit 2)))  ;a default and no null bit code conflict so
        )                               ;this reduces bit by 1 if odd, to allow null
        (if (= " " (substr msg (strlen msg) 1))            ;no def, if last char is space
          (setq msg (strcat "\n >> " (substr msg 1 (1- (strlen msg))) " : ")) ;then strip space
          (setq msg (strcat "\n >> " msg " : "))                ;else msg OK
      ) );if,if
      (initget bit kwd)
      (setq inp (getint msg))       ;use the GETINT function
      (if inp inp def)              ;compare the results, return appropriate value
    );defun
ureal ustr upoint .... 皆可比照 (from Google ...)
GMT+8, 2025-7-30 11:56 , Processed in 0.153025 second(s), 20 queries , Gzip On.
